Author Topic: [IC] Spectacle 80 | Subtle Curves, With Character!  (Read 12572 times)
Offline Kezewa
« on: Fri, 10 November 2023, 01:10:36 »
Spectacle 80
The next entry of the Spectacle line-up.
Contents
Introduction
Design - inspiration and philosophy
Specifications
Measurements
Pricing / Customization
FAQ
Pictures
Introduction
The Spectacle 80 is our next flagship release. Teaming up with KEZEWA for this release, we will be running the Spectacle 80 as an IN-STOCK product.
Following the same design philosophy as it’s predecessor, the Spectacle 80 delivers a beautifully designed experience. With symmetry and subtlety being the main focus, the Spectacle 80 is yet another stunning entry.
Design - Inspiration and philosophy
When starting the design process of the Spectacle 80 we turned to nature for inspiration.
Inspired by the elegance of butterflies, it became the main inspiration.
Continuing the 5-axis machining, loved on the predecessor, the Spectacle 80 features beautifully designed curves to accentuate it’s profile.
The design comes to life from all angles, from rear - with an elevated look, making it seem as if the board is floating - to front, with a perfect symmetry in the top and bottom half.
Combining the smooth curves, floating design, screwless exterior and the integrated seam, the Spectacle 80 is our most refined product to date.
Specifications
Weight: 2.2kg (4.85 lbs)
Typing angle: 8 deg
Mounting style: Top Mount
Front height: 18.8 mm
Layout: F12 TKL WK/WKL
Case material: 6061 Aluminum
Weight material:Stainless Steel (PVD Coated)
Plate Material: 5052 Aluminum
Foam: TBD (Please answer in form)
Packaging: Carry Case
Measurements
The Spectacle 80 will be customizable in a handful of ways.
Pricing: $399
Colors: Black, Silver and Grey
Stock: 90 Units (30 of each color, weights unlimited)
FAQ
Q: When will this be available?
A: We are aiming for Q4 2023
Q: What vendors will you be partnering with?
A: Currently undecided - we hope to have vendors in: EU, NA, OCE, CH, SK, VN, TH.
Q: Will there be more stock?
A: Depends on the demand. If the first sale goes well, we plan to release an additional batch.
Q: What will be included?
A: Top Case, Bottom Case, Plate, Weight, Screws, Carry Case.
Q: Where can I follow the project?
A: Here on Geekhack, or through our Instagram @StilouStudio
Q: Why does this not look like the Spectacle 60?
A: The Spectacle 80 is simply a part of the Spectacle design series. Our goal is to re-imagine and re-invent what we believe to be the most refined design for each layout. All while keeping the same minimalistic approach.
Q: Will any influencers be looking at the board?
A: Yes! We plan to have around 8 influencers review/build the board. We will update this comment as reviews are released!
Q: Is this a collaboration?
A: Yes! We have decided to partner up with KEZEWA after the success of the Spectacle 60 launch.
Q: How can I share my feedback?
A: There are multiple ways to do so. Either leave a comment here on Geekhack, fill out the form at the top of this post or contact us on IG or Discord and we’ll be happy to hear your feedback!
Pictures
Renders
« Last Edit: Fri, 10 November 2023, 01:19:09 by Kezewa »
Re: [IC] Spectacle 80 | Subtle Curves, With Character!
« Reply #1 on: Fri, 10 November 2023, 04:04:55 »
Looks unstable.
Offline Stilou Studio
  • Formerly Seo
  • Danish Designed Keyboards
« Reply #2 on: Fri, 10 November 2023, 11:09:46 »
Looks unstable.
Hey, I can assure it is not.
Alexotos built one on stream, and a viewer had the exact same concern.
Here is a clip from his VOD: https://www.twitch.tv/videos/1967938984?t=02h05m55s
Offline DaaDaa
« Reply #3 on: Sun, 12 November 2023, 15:53:29 »
I don't see any mention of the PCB in the entire post.
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline Woovie
« Reply #4 on: Sun, 12 November 2023, 22:44:40 »
Damn that's pretty. Hopefully you make a 60% in the future, GLWIC!
Offline KenGuru
« Reply #5 on: Tue, 14 November 2023, 08:23:54 »
there's already a spectacle60
Offline NeonThunderX
« Reply #6 on: Tue, 14 November 2023, 08:42:00 »
They already did, last year i think. this is their second design. it's called spectacle60
« Reply #7 on: Tue, 14 November 2023, 10:18:16 »
Not seeing a form link or any mention of the PCB. If it's BYOPCB which ones are compatibility?
Offline Exquite
  • GeekAnubis
« Reply #8 on: Tue, 14 November 2023, 15:33:04 »
Looks clean!
I'm a Color lover and a designer.
Offline PrizeOcelot5911
« Reply #9 on: Thu, 16 November 2023, 00:57:56 »
He looks very simple and elegant!  :thumb:
Offline EdgeOfInfinity
« Reply #10 on: Tue, 21 November 2023, 13:36:29 »
great looking design! really elegant. glwic!
« Reply #11 on: Thu, 23 November 2023, 03:41:29 »
The sense of heavy machinery used by boys. :cool:
« Reply #12 on: Tue, 28 November 2023, 16:44:24 »
also wanted to throw in, i could see this design being nicely adapted to an Alice-style board.
