Author Topic: [IC] Customize Keyboard - TMGC65 Pet-Element Keyboard  (Read 3274 times)
Offline Mykeeb
« on: Fri, 10 November 2023, 09:34:35 »
Hello everyone,
Today, we would like to introduce our first pet-element keyboard, TMGC65, from Tibers Studio.
TMGC65 Specifications:
●Typing angle: 7°
●Front height: 21mm
●Plate GASKETS structure
●Both PCB and Plate adopt flex-cut design
●PCB gasket jackets or socks (included as default)
●QMK/VIA Supported (wire version)
●Support PCB stabilizers
TMGC65 Features:
●100% processed using CNC machining with 6063 aluminum case and e-coated backplate.
●Compact 65% layout
●1.2mm Wired Flex Cut Hotswap PCB
●1.2mm Dual-mode Flex Cut Hotswap PCB(Wired and Bluetooth)
●Poron Plate Foam
●IXPE Foam
●Flex Cut & None Flex Cut Poron Case Foam
●Type-C Daughterboard with JST Cable
●Plate gaskets mount
TMGC65 Plate Options (Per-key Flex Cut Plate):
●FR4
●PC
●POM
TMGC65 Case Color Options:
Pink
Blue
Green
Purple
White
White Protype
Green Prototype
(Click Red Above Can Open and See More TMGC65 Photos)
TMGC65 Weight Color Options
●Pink
●Blue
●Green
●Purple
●White
TMGC65 2 PCBs Options:
●Wired Flex Cut Hotswap PCB( 1.2mm, Multi Layout , Stepped Capslock, 6.25U, 7U, Split Backspace Bar, support QMK and VIA )
●Bluetooth Flex Cut Hotswap PCB( 1.2mm, Multi Layout , Stepped Capslock, 6.25U, 7U , Split Backspace, support QMK)
Price:
●Wired Version     -  US$169.00
●Bluetooth Version - US$179.00
TMGC65 Videos:
●White
●Green
https://youtube.com/shorts/4sVn2ChRadM
(the video link can not embedded here, pls copy the link and open it in the browser)
●Pink
https://youtube.com/shorts/snSL3NSAGjQ
●Purple
https://youtube.com/shorts/TDheylbENPU
If you are interested in the TMGC65, pls kind fill in the IC Form.
Regards
Mykeeb Studio
« Last Edit: Fri, 10 November 2023, 09:36:23 by Mykeeb »
