Author Topic: [In-Stock] Class80 R2 by MM Studio  (Read 56639 times)
Offline Totoro
« on: Tue, 14 November 2023, 00:56:04 »
Hello Everyone,We are MM Studio.Today we are thrilled to present the Class80R2
for In stock FCFS. Thanks for your all attention and support again!
Welcome to our Discoard
GB Information
Sales Date: November 15th, 2023
Quantity: 200 units
Colors: Retro E-White, Retro E-Red,  Retro E-Green,
Shipment:  FCFS Instock sale, Order fullfilled within 1 mouth
Prices:
A-Stock: Wired standard kit: $355 / Wired Capacitive kit: $450
B-Stock: Wired standard kit: $305 / Wired Capacitive kit: $400
(B-Stock Keyboard may have minimal flaws and scratches, which will not affect its functionality or overall performance.No refund or exchange for B-Stock after purchase.)
Extra Foam Kit(Optional): $15
Extra extra accessories kit: $5
Group Buy Vendor list:
US: KFA
KR: Monstargear
VN: MOKB
The rest :www.mmkeyboard.com/
1.Changes from IC: Indicator light module will be free.
2.Case Option: Retro E-White & Retro E-Red & Retro E-Green
3.Inner Structure: Buzzer and solenoid will provide you unique typing experience
 and SS inner weight with special surface treatment.
Top mount, gasket mount(Plate-less supported)
5.PCB Options :
Hot-swap, Solder version PCB: 1.6mm no flex cut.
1.6mm Wired Capacitive EC kit Includes: Niz standard sliders, domes(48g),platestabs etc. (Everything except keycaps)
P.S: All Class80R2 PCB will support Class80 R1 case.(Class80R1 PCB won't support R2 case)
Layout & Exploded view
Keyboard info:
Color: Retro White/Retro Red/Retro Green
Keyboard size: 393.4mm* 189.5mm* 20mm(L*W*H)
Typing Angle :7"
Weight: 3.3kg (Case and weight only, unbuilt)
Case material :6063 aluminum
Badge: Blank badge as standard with an additional random badge the same color as the case.
Buzzer and Solenoid
Mounting : Gasket(plateless supported) & Top mount
Weight: Stainless steel
PCB: Soldered(with 5mm Plateless foam)/Hot swap/Wired EC kit(with sliders, domes(48g), platestabs etc.)
1.5mm plate: Standard POM/stainless steel ( EC only)
Mod Edit: Updated title tag to [In-Stock] to match sale format; OP, please remove this note when you see it
« Last Edit: Wed, 22 November 2023, 11:29:48 by HoffmanMyster »
Re: [In-Stock] Class80 R2 by MM Studio
« Reply #1 on: Wed, 22 November 2023, 11:30:05 »
Approved :thumb:
