Author Topic: Hi I'm new and also have a problem  (Read 7822 times)
Offline chris_R
« on: Fri, 17 November 2023, 13:10:40 »
Hi I'm Chris
So it all started with a cheap blackwidow with mx blue switches, then some mx black as my co workers hated the noise.
Then I found a few model M boards at a local auction
and now I've found a even older IBM 3277
Offline Rhienfo
  • GOTHETIGES
Re: Hi I'm new and also have a problem
« Reply #1 on: Fri, 17 November 2023, 15:05:23 »
Welcome to geekhack :)
I wish I was you and hit the jackpot like that.
How much did you pay for that?
Offline chris_R
« Reply #2 on: Fri, 17 November 2023, 16:07:09 »
I think it was around 150 nzd for the whole lot, my memory is a bit hazy
Offline Rhienfo
  • GOTHETIGES
« Reply #3 on: Fri, 17 November 2023, 21:05:07 »
damn what a deal, got so lucky there.
Offline oilumiun12
« Reply #4 on: Thu, 14 December 2023, 00:45:45 »
I think you hit a great bargain. Congratulation   :))
Offline diyachronic
« Reply #5 on: Thu, 14 December 2023, 09:00:17 »
I love that you went from MX cherry blues that your coworkers complained about because of the noise
And then went for the nuclear option and got IBM buckling spring/beam spring
You should add a solenoid and bring it to work  :cool:
Offline mohawk1367
  • Typing on: HHKB Pro Hybrid Type-S
« Reply #6 on: Fri, 15 December 2023, 06:47:15 »
Hi I'm Chris
wtf bro skipped the whole hobby and went straight to the end  :))
someone needs to make an aussie keyboard community called QMƎɹ┴⅄. get it? haha :D
Offline mohawk1367
« Reply #7 on: Fri, 15 December 2023, 06:47:57 »
not for the 3277 though, right...?
