Author Topic: [Preorder]DCD Bird Jungle - Pre order Closed  (Read 87571 times)
Offline arq1999
« on: Tue, 21 November 2023, 17:17:27 »
Based on a vintage Reel
Pre order is LIVE
Kitting
Hibi Collab
Deskmat Design by Roksow
Specs: Rough Texture, 90x40, 4mm - PRICE - $29
Pictures
Details and Prices
Material: Dye sub PBT
Shipping ETA: April 2024
Early Bird Prices:
Base Kit - $59
Novelties Kit - $25
Accents Kit - $29
Deskmat - $29
Hibi EGG - $55
Hibi Tray - $59
Renders
Werk.One - Werk Technica
Austin
TGR 910
TGR Alice
W1-AT
Instragram: Arqkeebs
Discord: arq1999#1999
Join my discord
Acknowledgement
-To my wife Annie
-To Bingo for the renders and support
-To my friends Luis, Daniel, El Valencia
-To Roksow for making such a beautiful deskmat. Please check out his work
-To Angel for making this project come alive. Many of my projects couldn't have come alive without his help. Also please check out his work
Show Your Support by Using This Signature! Thank you
Code: [Select]
[url=https://geekhack.org/index.php?topic=119073.0][img width=330 height=120]https://i.imgur.com/H9xmU1U.png[/img][/url]
« Last Edit: Wed, 03 January 2024, 10:26:59 by arq1999 »
Offline exitfire401
  • The Force is Re/\l
Re: DCD BIRD JUNGLE - PRE ORDER LIVE
« Reply #1 on: Wed, 22 November 2023, 11:39:07 »
Approved
Mod Edit: Hijacking exit's post to add the usual PSA
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
« Last Edit: Wed, 22 November 2023, 11:44:33 by HoffmanMyster »
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #2 on: Wed, 22 November 2023, 11:41:36 »
glwpo
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [Preorder]DCD Bird Jungle
« Reply #3 on: Wed, 22 November 2023, 19:14:37 »
absolutely grabbing a mat. keyset... maybe if i can sell a friend on it. happy to see you make it this far with this set
Offline vhaarr
« Reply #4 on: Thu, 23 November 2023, 00:04:05 »
Awww no nordeuk :sadface:
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline Mecxs
« Reply #5 on: Fri, 24 November 2023, 17:49:12 »
Prices look pretty good.
Deskmat is excellent.
There appear to be several errors in the novelty and accent kits:
- Novelty backspace labelled as 2.25u
- No R2 1.75u novelty backspace (making the 1.5u enter largely redundant)
- Fourth 1.5u R4 novelty is labelled as 1.25
- "Aceents Kit"
- R2 Pipe accent is labelled as 1.75
- No R2 1.5u accent backspace (now there's a 1.75u present for minivan, but you can't do tab + 1.5u backspace)
- Red ANSI enter accent labelled as 2.00
Overall a nice set, but I'd be hesitant to buy with those kitting errors since trying to wrangle Drop customer support in case of any missing keys is awful.
Offline arq1999
« Reply #6 on: Sat, 25 November 2023, 15:23:01 »
- "Aceents Kit"
Hey, thanks for the feedback:
Ill be updating the renders once I have them:
- "Novelty backspace labelled as 2.25u " - wrong label but the production file its correct.
- "Fourth 1.5u R4 novelty is labelled as 1.25" - wrong label but the production file its correct.
- "R2 Pipe accent is labelled as 1.75" - wrong label but the production file its correct.
- Red ANSI enter accent labelled as 2.00 - wrong label but the production file its correct.
For the following keys. I have already prepare an email to DROP to see if its possible to add them. If it gets approved Ill be posting it here. This is totally my bad tho.
Offline arq1999
Re: [Preorder]DCD Bird Jungle - Kitting Fix
« Reply #7 on: Wed, 29 November 2023, 16:11:29 »
updated the kitting the with previus mention changes!
Offline arq1999
Re: [Preorder]DCD Bird Jungle - 4 days Left
« Reply #8 on: Sun, 17 December 2023, 17:09:55 »
DROP is running a giveaway in instragram.
https://www.instagram.com/p/C05NtNDsv7s/?img_index=1
