Author Topic: Matias Quiet Pro on a Mac  (Read 27335 times)
Offline Belfong
« on: Thu, 23 November 2023, 03:18:19 »
So, I have this Matias Quiet Pro (for Windows) but is now plugged into the Mac. In macOS, I can use software settings to swap Win key into Option and Alt into Command. All is well. But, I notice there is a Fn key between the Right Alt and Right Control. Pressing it did not register anything. I even try using KeyCodes and Karabiner (and Keyboard Maestro). I suspect this is something really low level that has to be done in firmware level. Have anyone tried to do anything to get this Fn key recognise in Mac?
(This is probably a unique use case, so maybe Matias himself can give some pointer)?
Offline funkmon
Re: Matias Quiet Pro on a Mac
« Reply #1 on: Tue, 28 November 2023, 11:13:44 »
I have tried with no success. I do believe the function key is at a firmware level.
