Author Topic: 【IC】Infi100- 98%layout, Leaf-Spring mount, Supporting wirlesss and bluetooth  (Read 17409 times)
Offline evanzh
Greetings, fellas from GeekHack
We are Keyverse from China
In early April of this year, We lunched our first 75% layout Mechanical keyboard -  Infi 75
304539-0
Base on the experience accumulated over seven month , we decided to launch a 98% layout keyboard- Infi 100
This time our inspiration came from the McLaren P1
The minimalist lines that exude personality and asethetic appearl are what we strive for
304543-2
304545-3
304547-4
Those taillights are not only designed to showing the keyboard characteristic  but they also control the WIN/MAC and 2.4G Wireless/ Bluetooth
Our goal for keyboards has always been the pursuit of " extreme "
Our First keyboard “Infi 75 ” We invented the Hifi-Pad and first used it on the mechanical keyboard
It can improve the sound making on the PCB with Rgb lightings
This time, we have taken the “ Extreme “ to another level
Not only this Keyboard is fully Aluminum alloy CNC processing with powder coating  but also our price is under $150
Without further ado
304549-5
304551-6
304553-7
304555-8
Basic version
Layout:  98%
Mounting: Leaf-spring mount
Typing Angle: 7.5°
Front Height: 19.30mm
Powder coating : Black Flash or White Flash
PCB: 1.2mm Hotswap with RGB 2.4 wirless and bluetooth
Plates: Polycarbonate(1.5mm)
Top and bottom : 6063 Aluminum
Bottom cover with aluminum 6063
Battery capacity: 3000mah
Weight: 2.2kg
Price: under $115
Keyboard come with Switches and keycaps
"TianQing" Switch
       Linear Switch
       Top housing:PC
       Stem :POM
       Bottom housing:Nylon
       Spring: 55g 18mm
       Travel Distance: 3.6mm
       Manufacturer: KTT
304569-9
1.The Black Engine (Black Flash)
304557-10
304559-11
2.Elf Warrior (Gary Green)
304561-12
3.Pink Mechas “Tokki” (Pink Flash)
304563-13
4.White Sculptures (White Flash)
304565-14
5.Death Star (McFlurry)
304567-15
Specification
Layout:  98%
Typing Angle: 7.5°
Powder coating : Black Flash ,White Flash, Gary Green, Pink Flash and McFlurry
bottom cover with Stainless Steel
Battery capacity 6000mah
Weight: 2.7kg
Price: under $150
Came with Switches and Theme keycaps
“YunMu” Swtich
      Linear Switch
      Top housing:UPE
      Stem :K3
      Bottom housing:UPE
      Spring: 55g 18mm
       Manufacturer: Jwick
304571-16
304573-17304575-18
Hope you enyjoy
If you have more questions leave a comment.
If you want to contact us  you can send message to  Keyverse_official@hotmail.com
« Last Edit: Tue, 12 December 2023, 02:25:28 by evanzh »
Offline hangul
will there be any screens? I'm not sure if that is a drawing or a screen.
Offline Exquite
  • GeekAnubis
Looks fancy!!!
I'm a Color lover and a designer.
Offline evanzh
The initial idea was  put a touch screen,  but we drop it .  due to  Cost control and development cycle
Offline HaloShiroe
  • looking for work
This looks super cool, but I'm not too much of a fan of full sized layouts
how are you able to do leaf spring for only $115, seems a bit nuts?
Offline FlashBombGod
I love everything about this board except for the plate-mounted stabs. Would it be possible to support PCB-mount stabs?
Also, when will this be available, assuming it's going to be released? :O
Offline Kokaloo
  • 🤘(• ω •)🤙
i love china
Offline longcao1010
Lovely boards, any chance for a full-size layout later in your plan?
I have to say this is the best full size custom keyboard I have ever seen! When will be your GB open?
The keyboard is actually for sale already in-stock. Simply search up the board in a cursory Google search, and you should be able to find it for sale on AliExpress, Mech.keys, or some other vendors. :)
