Author Topic: [GB] WIND X98 R2,Southpaw available,GB 28th Dec to 11th Jan  (Read 43206 times)
Offline windlabs
« on: Thu, 21 December 2023, 03:28:36 »
Hello,
We are wind studio.
Thanks for your expectation on wind x98 r2. We decided to start wind x98 r2 on 28th Dec.
More details about wind x98 r2 keyboard kit you can go to check this link:https://geekhack.org/index.php?topic=121998.0
1.Update
The pcb layout of GB production will be updated as this picture. The normal pcb is the same as southpaw pcb, the wired hotswap pcb and bluetooth pcb will include two numpad pcbs,
one support enter left,one support enter right. So southpaw pcb available on bluetooth,hotswap, enter left and enter right layouts at same time.
Support split backspace.
2.Special Note
All parts are the same between normal keyboard and southpaw keyboard, except top upper case. So if you buy normal keyboard and an extra southpaw top upper case, then it can change to a southpaw keyboard.
3.Group buy details
①Price:Wired $320, Bluetooth $335
②Group Buy Date: 28th Dec 2023 to 11th Jan 2024
③Group Buy Payment:On our vendor list
USA:
https://divinikey.com/
Canada:https://www.ashkeebs.com/
Korea:https://www.monstargears.com/
Vietnam:https://thekeebs.store/
Thailand:https://ntchkeys.com/
Malaysia:https://www.rebultkeyboards.com/
Philippines:https://zionstudios.ph/
Singapore:https://pantheonkeys.com/
Japan:https://basekeys.jp/
Indonesia:https://kukey.studio/
South American:https://fancycustoms.com/
Australia:https://www.switchkeys.com.au/
Europe:https://keygem.com/
United Kingdom:https://mechboards.co.uk/
Taiwan:https://www.inpad.com.tw/
Others:https://windstudio.store/collections/wind-x98-r2
④Shipping: 3-6 months
⑤Package include:
X98 keyboard case(top case/bottom case)
1.6mm No Flex Cut PCB Optional
1.5mm PC Plate
PC front accent piece
X PVD logo or Square logo
Foam kit(1mm poron + 2mm poron + 2mm hotswap foam + 0.5mm IXPE sheet + 3.5mm poron)
Gateron stabilizers set(6*2U, 1*6.25U)
Brass weight
User guide
Accessories Bag
The default package will be included PC plate and PC front eccent piece. You can buy extras if you want brass weight,other plates.
You can check all wind x98 r2 product page here:https://windstudio.store/collections/wind-x98-r2
4. Extra price
Extra price:
Wired Hotswap PCB: $20/pcs
Bluetooth Hotswap PCB: $35/pcs
Soldered PCB: $20/pcs
Foam Kit: $10/pcs
PC Plate: $15/pcs
ALU Plate: $15/pcs
FR4 Plate: $15/pcs
Brass Plate: $25/pcs
PC Front Accent Piece: $10/pcs
Brass Front Accent piece: $10/pcs
X logo: $20/pcs
Square Logo: $20/pcs
Brass Weight: $35/pcs
X Shape logo Normal Top Upper Case: $65/pcs
Square Shape logo Normal Top Upper Case: $65/pcs
X Shape logo Southpaw Top Upper Case: $65/pcs
Square Shape logo Southpaw Top Upper Case: $65/pcs
Note: the top case do not include logo and accent piece
5.Color choice
Grey 416U+Blue 288U (6063Alu, anodized)
Black+Black(6063Alu, anodized)
E-White+E-White(6063Alu, cataphoresis)
E-White+E-Pink(6063Alu, cataphoresis
Creamy white(6063Alu, cataphoresis)+Brown 7584u(6063Alu, anodized)
Semitransparent(PC)
Real photo:
There will be more review video, join our discord and discuss anything!
Discord:https://discord.gg/DhpytJTy7c
Offline Keeblord_Elf
Re: [GB] WIND X98 R2,Southpaw available,GB 28th Dec to 11th Jan
« Reply #1 on: Wed, 17 April 2024, 12:22:53 »
Any updates on the status of fulfillment of the WindX98 R2?
I think I saw 3-6 months after GB ends, but i'm wondering if that's still the case?
