Author Topic: Anybody able to tell if this could possibly not be rubber dome?  (Read 2444 times)
Offline NewbieOneKenobi
« on: Mon, 18 October 2010, 15:32:59 »
Link: http://www.delllow.com/go/_info/index.php?user_id=k1&lang=en&idc=16_9_60&page=2&sess_id=cbf1de32fc3ecff0cfb15a7e01d5e576
BTW, the vendor does have pre-1992 Model M's for $35 apiece (not listed there) but shipment from Poland would cost some ($37 for one, $53 for two, $65 for three and so on judging by the prices of our postal service, possibly a couple bucks more if they exceed 2 kilos of weight).
Offline CeeSA
« Reply #1 on: Mon, 18 October 2010, 15:38:34 »
link to nirvana....
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #2 on: Mon, 18 October 2010, 16:39:42 »
Works better without session ID.
'fraid that's a rubber dome, and not even one of the good FSCs (which would have keycaps with a spherical rather than cylindrical cross-section, as well as a shorter RShift on older samples).
The site still seems wacky though. In any case the only mechanicals I've seen listed are ML4400s (Cherry G84-4400, ML switches with trackball).
« Last Edit: Mon, 18 October 2010, 16:46:14 by keyb_gr »
« Reply #3 on: Mon, 18 October 2010, 16:57:35 »
Thanks. Sorry for not noticing the linking problem.
I've recently managed to get 3 split FJS keyboards from a different vendor through the same site, $7 each (IBM rubber dome SK8820 were $3 each and I broke my wpm record the first or second time I plugged one in, which was after a year of using scissors... you can't get much better with a dome than this).
Offline keyb_gr
  • Cherrified user
« Reply #4 on: Mon, 18 October 2010, 18:00:34 »
Quote from: NewbieOneKenobi;235640
KBPC Es? Not a bad deal. NKRO, too...
The older RapidAccess Keyboards are supposed to be the best IBM 'domes though. Should be KB-8923 and KB-7993.
Looks like the SK-8820 isn't a bad modern-day office workhorse though, even if they're probably made in one of those factories with precarious working conditions in mainland China...
