Author Topic: [IC] 60+  (Read 8698 times)
Offline nuxroskb
    • Keyboard from Vietnamese Maker
[IC] 60+
« on: Fri, 05 January 2024, 09:52:16 »
Hello everyone, now I would like to introduce to you a new product called 60+(60plus)
IC FORM  DISCORD  INSTAGRAM
This is a project I ran V1 before with the name RE60 Slim. After completing private GB V1. I have received many reviews, both good and bad.
Good reviews in V1 are as follows:
+ Even sound, good typing feeling, beautiful appearance.
Bad reviews:
+ Anode surface finishing is not good
+ The problem of oxidized weights.
+ Mod has a slight echo
The above problems occurred because I chose a poor factory, and the factory in Vietnam does not produce good quality like foreign factories, especially China.
But in return, the private GB V1 (RE60 Slim) price is very reasonable: 6,200,000 VND (~$263.8)
RE60 Slim V1
Sountest V1:
For V2 (60+), I have tweaked the design a bit to make it more eye-catching.
Slightly edited the inside of the case and plate to produce better sound, improving the sound of the mod (characteristic of top-mount).
Added 1 additional mounting: Gasket mount
In order for the product to reach users with the best quality, for 60+ I chose a factory in China, Kezewa (Maker Enter67..)
Basic information:
Top: Aluminum 6063
Bottom: Aluminum 6063/ PC
Weight: SS/ Copper
Plate: Aluminum 5052/ POM/ CF
PCB: Solder only (Support QMK/VIA)
Mounting: Topmount + Gasketmount (Dual mounting)
Layout support HHKB-True HHKB-WKL-WK
Carrying cases
Feet 3M
Estimated price: $450~500$
Only 25 units produced
PCB layout support WK/WKL/HHKB/TrueHHKB
Timeline
- Make a prototype
- Build & Soundtest
- Send streamer
- Open GB
Estimate open GB time:
1/20/2024
Q: How can I buy it?
A: You can buy it through my website
https://nuxroskb.store/blogs/tin-t%E1%BB%A9c/ic-60plus-60-a-new-limited-keyboard
Q: Will you run again?
A: This product is only produced once
« Last Edit: Sat, 06 January 2024, 01:33:13 by nuxroskb »
Offline thuc
Re: [IC] 60+
« Reply #1 on: Fri, 05 January 2024, 10:58:38 »
GLWIC bro, nice keeb
Offline azhdar
  • Praise the AZERTY god
Re: [IC] 60+
« Reply #2 on: Fri, 05 January 2024, 11:43:49 »
ne iso ?
Azerty Propagandiste
Offline takuto
Re: [IC] 60+
« Reply #3 on: Fri, 05 January 2024, 13:36:47 »
Great looking board, but WK-only, solder-only and price makes this a pass for me.
Just a suggestion: You may also wanna post some internal renders or prototype pics.
Offline KeebRehab
Re: [IC] 60+
« Reply #4 on: Fri, 05 January 2024, 20:38:07 »
"Q: Will you run again?"
Me: Why would I ask that when this run hasn't happened...?
Offline involuntarysoul
Re: [IC] 60+
« Reply #5 on: Fri, 05 January 2024, 21:45:05 »
no WKL?
« Last Edit: Fri, 05 January 2024, 21:46:52 by involuntarysoul »
Offline nuxroskb
Re: [IC] 60+
« Reply #6 on: Fri, 05 January 2024, 22:44:32 »
no WKL?
Sorry, I missed this information.
The boards will support WKL/HHKB/True HHKB/WK
Offline nuxroskb
Re: [IC] 60+
« Reply #7 on: Fri, 05 January 2024, 22:46:55 »
Yes I will add more.
I just checked that maybe I forgot to add information that the board supports HKKB/True HHKB/WKL
Offline nuxroskb
Re: [IC] 60+
« Reply #8 on: Fri, 05 January 2024, 22:48:28 »
ne iso ?
If the user wants to add an ISO I can do that sir.
This is just the IC I will add to the final version
Offline vhaarr
Re: [IC] 60+
« Reply #9 on: Sat, 06 January 2024, 01:18:51 »
Could you make a KLE image that shows the PCB support? http://www.keyboard-layout-editor.com/
Every IC/GB does this, if you need to see what I mean just read the IC for another keyboard.
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline nuxroskb
Re: [IC] 60+
« Reply #10 on: Sat, 06 January 2024, 01:33:50 »
Update!!! Thank you so much!
Offline LMarci
Re: [IC] 60+
« Reply #11 on: Sat, 06 January 2024, 08:40:20 »
Cool board but the IC could use an explosion diagram/plate pics/internal pics.
Offline aristus
Re: [IC] 60+
« Reply #12 on: Sat, 06 January 2024, 13:23:58 »
I'm actually fond of the design, but I think you should just raise the unit cap to lower the cost.
