Author Topic: [CLOSED][GB] ZERO-G x Hammer Works Mirror Image Keycaps  (Read 18041 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Sat, 06 January 2024, 21:16:08 »
ZERO-G brings a new design theme to the community. The Mirror Image.
Let's go into ZERO-G's mirror world.
KEYCAPS
The keycap makes of PBT material and print with dye sublimation. Moreover, ZERO-G finally decides to add 40-kit, including a 1.75u Backspace, for 40-layout collecters.
DESIGN
The main colour is retro-cream white. In Alpha-B and Alph-C, ZERO-G uses rainbow colour on letters. By ZERO-G words, the Alpha-B is parallel universe, the Alpha-C is the mirror space. For sure, you can mix them and make your own mirror world.
SPEC
Cherry profile
PBT dye sublimation
Manufacture: Hammer Works
ZERO-G Geekhack IC page
GB Timeframe
Start on 22nd December 2023 PST
GB Closed on 15th Jan 2024 PST
ONLY 100 Kit available for this GB.
Join KPrepublic Discord server to follow the status
GB PAGE
« Last Edit: Fri, 26 January 2024, 01:17:05 by KPrepublic »
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: [GB] ZERO-G x Hammer Works Mirror Image Keycaps
« Reply #1 on: Sat, 06 January 2024, 21:54:31 »
