Advanced search
typing on a cloud of . . .
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Interest Checks
(Moderator:
Signature
[IC]Wikuo Fuyu switch
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [IC]Wikuo Fuyu switch (Read 3599 times)
moyu.studio
Thread Starter
on:
Mon, 08 January 2024, 00:06:56 »
Hello,This is Moyu.studio
This time we bring the fuyu switch
The inspiration for the fuyu switch comes from the fuyu keycap (authorized by the designer),Made by Wikuo and using their latest cross stem mold.
fuyu switch Specifications:
- Linear
- 58g spring(18mm)
- POM Lengthen stem
- Polymer nylon top housing
- Polymer nylon bottom housing
- 5 pin
- 3.5mm Travel
- Made by Wikuo/Lichicx
- Mild lubrication
- Designed by Moyu.studio
On the fuyu switch, we used the latest cross stem mold from wikuo/lichicx, which has undergone multiple modifications and adjustments before its official launch to ensure the best feeling can be achieved.
In terms of materials, we have selected multiple nylon materials
After repeated experiments and comparisons, this polymer nylon was ultimately selected
Finally achieving a balance between smoothness and sound
A total travel of 3.5mm will also make the overall sound more HIFI
But it won't make the feel abrupt
In the past, we have always been fans of fuyu keycaps, from GMK fuyu keycaps to Milkyway fuyu keycaps.
It is a great honor to have the designer's authorization this time, so we also hope to create a perfect switch: the sound is just right, the extreme smoothness, the affordable price, and the stable switch
On the fuyu switch, we constantly adjusted and after several rounds of debugging, we finally got what we wanted, hoping to also be liked by the community
In terms of lubrication, we used a very light and thin lubrication scheme, using only a small amount of lubrication on the areas where the stem and leaves come into contact and on the sides of the stem
This ensures that there will be no noise when the switch is opened, and it will also highlight the feeling of the switch itself
You can use it right out of the box, there's no problem with it
Of course, this also ensures that you can add lubrication according to your preferences, without the need to clean the lubrication of the switch itself
Whether you are a factory lubrication enthusiast or prefer to lubricate yourself, the fuyu switch is easy to achieve
Sales method: Inventory sales (We hope you can get it immediately)
Vendor:TBD
Price:0.44$/PCS(Adjustments will be made according to the region)
Time:Around the end of Februar
y
Join our Discord
[/size]
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
Interest Checks
(Moderator:
Signature
