Author Topic: KBD67 Lite R4 compatible cases?  (Read 4494 times)
Offline jackcalico
« on: Sat, 13 January 2024, 08:38:14 »
Hi, are there compatible KBD67 Lite R4 cases?
Offline Sup
Re: KBD67 Lite R4 compatible cases?
« Reply #1 on: Sun, 14 January 2024, 16:29:52 »
no
current
Coming soon
Offline jackcalico
« Reply #2 on: Mon, 15 January 2024, 01:23:11 »
Are you sure? If I recall correctly they had an aluminum version, but maybe that was only compatible with the previous batch. Can't recall.
Offline Sup
« Reply #3 on: Mon, 15 January 2024, 02:51:44 »
And you are right. There is a case but, its only compatible with R1/R2 and R3
current
Coming soon
Offline Exquite
  • GeekAnubis
« Reply #4 on: Fri, 19 January 2024, 22:01:14 »
R4 is relatively new and a bit different so I think there are no aluminum options.
I'm a Color lover and a designer.
