Author Topic: Where to buy GMK dark?  (Read 49472 times)
Offline kimberly
« on: Wed, 17 January 2024, 20:08:07 »
I want to buy GMK dark so badly, but cannot find a single website to buy this on.
Does anybody know where to buy it?
I've checked there is one in ebay, but it is used one..
« Last Edit: Wed, 17 January 2024, 20:10:14 by kimberly »
Offline Rhienfo
  • GOTHETIGES
Re: Where to buy GMK dark?
« Reply #1 on: Wed, 17 January 2024, 21:50:37 »
GMK Dark is no longer available to purchase new since it was a group buy that ended ages ago. You can only get it used right now, unless an r2 happens, which doesn't seem likely.
Offline xjack312
« Reply #2 on: Thu, 18 January 2024, 15:10:28 »
There are some sets that are fairly similar, one that's going into GB soon is KKB Outer Bounds with dark alphas. More gray on black than black on gray but similar
Alice enjoyer
Offline kimberly
« Reply #3 on: Thu, 18 January 2024, 19:10:13 »
@Rhienfo I really hope that there is another group by for this.. Doesn't this look so cool? lol
@xjack312 Thank you so much for the information. KKB Outer Bounds also looks pretty cool!
Offline Rhienfo
  • GOTHETIGES
« Reply #4 on: Fri, 19 January 2024, 05:15:50 »
I do like gmk dark, though the kitting wasn't very great.
I looked into it a bit and I did see that the original runner was interested in doing an r2, not saying it will happen 100% though, but I would keep an eye on geekhack just in case an IC pops up.
Offline kimberly
« Reply #5 on: Sun, 21 January 2024, 20:29:15 »
OHHHHHH Thank you so much for the information!! I'll keep my eyes on geekhacck!
Offline Neongreen
« Reply #6 on: Tue, 06 February 2024, 21:02:18 »
I would be so excited for R2, black case with gateron oil kings would make the ultimate dark board.
Offline _rubik
« Reply #7 on: Wed, 27 March 2024, 15:26:02 »
kimberly, you may be interested in a recent IC for GMK Cosmos. Could scratch the same itch https://geekhack.org/index.php?topic=122582.0
Offline r201rotana
« Reply #8 on: Sun, 16 June 2024, 17:25:33 »
Does GMK Dark look similar to Dualshot R2? I've recently picked up the Katakana Base for Dualshot but the colored mods are throwing me off. I've been looking for other GMK with "N9" base and "CR" sub-legend sets to hopefully mix and match with it, and this is the closest I've seen. The only hitch is the renders make it look like Dark is much darker than Dualshot, even tho they use the same GMK's standard colors (from what it looks like).
Offline Rhienfo
  • GOTHETIGES
« Reply #9 on: Mon, 17 June 2024, 00:05:18 »
If they are both N9 then it should be similar, also look at irl images since both sets were released as those are more accurate.
« Reply #10 on: Tue, 02 September 2025, 23:42:56 »
GMK Shaded has a Base Kit that's got the exact same color codes as GMK Dark. Is also has another base kit that's the same color codes as GMK Grey on Black. Plus Alt Mods kits. GB is still live on Canonkeys till September 7
« Last Edit: Tue, 02 September 2025, 23:51:13 by MartinThePolarBear »
