Author Topic: Advice needed on ninth key on STB  (Read 4167 times)
Offline SirClickAlot
    • http://www.mrinterface.com
« on: Tue, 19 October 2010, 08:05:01 »
Progress so far...
Am pulling my hair on which key will be the ninth key. The first 8 are :
1. Cherry blue
2. Cherry brown
3. Cherry black
4. Cherry red
5. Cherry clear
6. Buckling spring
7. Alps clicky ( white )
8. Alps non clicky ( white )
9....?????
Got these I think about :
1. Cherry ML ( From g84-4100 )
2. Alps non clicky black ( from AT-101 )
3. Monterey blue ( coming up in several weeks )
Which one would be suited best as the ninth key on the Switch Try Board?
Regards.
« Last Edit: Tue, 19 October 2010, 08:19:52 by SirClickAlot »
[Succes is when you get what you want
Happiness is when you want what you get]
Optimize your interfaces : http://www.mrinterface.com
Currently using( not necessarily my favorite : I iterate over my collection many times ):
Filco White Majestouch Mx Brown DS White on Black.
Looking for : New and interesting interfaces. Working on :www.deskthority.net
woody
  •  Guest
« Reply #1 on: Tue, 19 October 2010, 08:21:09 »
Cherry ML, because keyboards with it are available.
________
ecigarettes
« Last Edit: Sat, 05 February 2011, 13:54:42 by woody »
Offline itlnstln
« Reply #2 on: Tue, 19 October 2010, 08:25:02 »
Second the ML.
Offline clickclack
  • Board Chow EXTRAORDINAIRE
« Reply #3 on: Tue, 19 October 2010, 08:46:16 »
Ml +3
« Last Edit: Tue, 19 October 2010, 08:49:22 by clickclack »
862+ keyboards and counting!   R.I.P.ster          Vendor link ->Clack Factory
Offline clickclack
« Reply #4 on: Tue, 19 October 2010, 08:50:13 »
So In my post above is there any reason why I can't capitalize the letter "L"?
I thought he already tried the Topre. Whoops! Wrong member, yeah I change it
to Topre! =)
« Last Edit: Tue, 19 October 2010, 08:53:07 by clickclack »
« Reply #5 on: Tue, 19 October 2010, 08:53:15 »
@Ripster : I also thought of that, but it is on its own trip right now ;-)
I might be able to convince Topre to give me 10 of those key chains so I can make 10 STB's with topre keyswitches on them. Anybody knows how to contact them ?
Regards.
Offline clickclack
« Reply #6 on: Tue, 19 October 2010, 09:18:15 »
CRAP! (I need some sleep)
I totally misread this entire thread, You are making the board I was making a while ago, but I thought interest faded.
Good for you buddy! =)
Cherry blue
Cherry brown
Cherry black
Cherry clear
Cherry red
Cherry ML
ALPS clicky (white)
ALPS soft clicky (green/blue)    X
ALPS non clicky (black)
ALPS linear    X
ALPS non clicky (dampend)  X
Topre 30   X
Topre 45
Topre 55
BS M
BS F    X
Space invaders    X
Scissor switch
Average rubber dome
Monterey   X
Some keys With standard, 2-shot, and my keys on it.
The Xs were  the ones I think I decided against because they were less common and very out dated or just really, really uncommon.
But better someone else does it anyway I have my hands full.
I hope it works out well whatever you choose =)
K I need to sleep now its been 26hrs zzzzzzzzzzzz....
« Last Edit: Tue, 19 October 2010, 09:20:46 by clickclack »
« Reply #7 on: Tue, 19 October 2010, 10:02:12 »
Quote from: clickclack;235914
Cherry blue
Cherry brown
Cherry black
Cherry clear
Cherry red
Cherry ML
ALPS clicky (white)
ALPS linear    X
Topre 30   X
Topre 45
Topre 55
BS M
BS F    X
Space invaders    X
Scissor switch
Average rubber dome
Monterey   X
Didn't know someone else already tried this....
How did you get the Topres?
Regards.
« Reply #8 on: Tue, 19 October 2010, 10:35:15 »
Quote from: ripster;235938
I think he has one Topre but never built a Frankenstein board.
I've had a Cherry MX tester board for some time now made from a $10 Black Cherry Chinese numpad.  I used it for spring/stem swapping tests.
Interesting....
Want to depart from it? *evil grin*
Regards.
« Reply #9 on: Thu, 21 October 2010, 05:42:38 »
Today I finally cut the gordian knot....
It wasn't possible for the buckling spring to be removed as a switch from my model m keyboard so I had to go with something else.
Cherries and Alps only for this first iteration of the STB ( switch try board ).
Now for the difficult task of mounting them to a pcb which doesn't have pre-drilled holes for the cherries... :-p
Regards.
Offline Moogle Stiltzkin
« Reply #10 on: Thu, 21 October 2010, 05:45:15 »
Maybe Topre i'd think. Or the Ml :X
Royal Kludge discount code:
Lowyat15
15 USD discount.
« Reply #11 on: Thu, 21 October 2010, 07:07:55 »
Gosh....
Didn't know they were such a pain to attach to a piece of PCB. I need to drill holes at exactly the right positions...
Ah well : my knowledge of keyboard switches increases every day!
Regards.
Offline muchadoaboutnothing
« Reply #12 on: Thu, 21 October 2010, 07:52:45 »
Quote from: SirClickAlot;235898
Regards.
I sent a letter groveling for a keychain shortly (days) before the keychain sink list started since I had never tried a Topre switch. $1.83 in postage from the US to Japan. Sent it in English, so I'm curious to see if I get a reply.
As far as contacting them, I found the address by Googling, but you seem to have it already:
