Author Topic: [IC] JRIS65&JRIS75 Glitter Spray-coated Version GB Live Now  (Read 3815 times)
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
« on: Mon, 05 February 2024, 20:39:21 »
Hi Everyone,
We are so excited that the JRIS65&JRIS75 Glitter Spray-coated Version GB Live today----The Chinese New Year's Eve. It is a time of gathering and celebration for families. It has traditional rituals, delicious feasts, and vibrant fireworks displays. We exchange good wishes and greetings for the coming year, ushering in fresh hopes and blessings. Now, all the best wishes to you all in advance.
Price:
JRIS65: $170
JRIS75: $175
GB Time
February 9th-20th or the GB will end once the total order reaches our order units.
Limited QTY
We have completed the CNC process, so JRIS65 and JRIS75 are each limited to only 100 units worldwide.
Estimated Delivery
Start packing and sending to vendors and Mykeyclub direct customers around six weeks after GB ends.
Vendor list
US: KeebsForAll
Canada: deskhero
UK: Prototypist
Germany: KEYGEM
Italy: Coffeekeys
AU: SwitchKeys
Singapore: Mecha.Store
Vietnam: MOKB STORE
Philippines: Zion Studios
Indonesia: KeebsMark
Thailand: NTCH Keys
International: Mykeyclub
JRIS65&JRIS75 Information
JRIS65 Specifications
Typing angle: 6°
Front height: 21.3mm
Dimension: 318.9*114*33.33mm
JRIS75 Specifications
Typing angle: 7°
Front height: 21 mm
Dimension: 325*142*39mm
Brass Internal Weight
Common Specifications
Material: Full CNC 6063 aluminum
PCB GASKETS structure
QMK/VIA Supported
Support PCB stabilizers
What's the configuration?
JRIS65:
Spray-coated With Glitter Case: Milky White/ Lilac/ Pink
Weight: Brass/ Silver PVD/ Black PVD/ Gold PVD
PCB: Wired Non-Flex Cut Multi LayoutHotswap PCB(1.6mm, No Per-key RGB, support QMK and VIA)
Plate: PC Plate
JRIS75:
PCB: Wired Flex Cut Multi Layout Hotswap PCB(1.2mm, No Per-key RGB, support QMK and VIA)
Plate: PC Plate
What's in the package?
JRIS65:
1x Full CNC Aluminum Case
2x External Weight
1x Non-Flex Cut Hotswap PCB
1x PC Plate
1x Type-C Daughterboard
1x IXPE Foam
1x Poron Plate Foam
1x Flex Cut Poron Case Foam
1x JST Cable
1 Set of Footpad
1 Set of PCB stabilizers O-ring
20x gasket socks
Gift(will not send make-up or replacements)
1x Customized Carrying Case
1x Customized Type-C Cable
1x Silicone pad of battery compartment
JRIS75:
2x External Weight
1x Brass internal weight
1x PC Plate
1x IXPE Foam
1x Poron Plate Foam
1x JST Cable
1 Set Anti-Shock Silicone Pad
1 Set of Footpad
26x Gasket Silicone columns
1x Customized PVD Artisan keycaps
1x Aluminium Alloy Screwdriver with 2 replaceable bits
1 x 2 in 1 Switch puller and Keycap puller
1 x Customized Masking Tape(Fit the flex cuts in the PCB perfectly.)
Please fill in theIC form if you have any thoughts. We love to hear from you.
For more discussions and future updates, please join Mykeyclub discord
Thank you so much for reading.
Best Regards
Mykeyclub Team
« Last Edit: Fri, 09 February 2024, 02:02:10 by Mykeyclub »
Offline Mykeyclub
  • MKC65 is coming!
    • Mykeyclub
Re: [IC] JRIS65&JRIS75 Glitter Spray-coated Version GB Live Now
« Reply #1 on: Fri, 09 February 2024, 02:02:20 »
JRIS65&JRIS75 Glitter Spray-coated Version GB Live Now :thumb:
