Author Topic: Bit of an odd question  (Read 3745 times)
Offline Scottyyy
« on: Wed, 20 October 2010, 08:52:41 »
Hey guys. First post here. I'm looking to buy a mechanical keyboard, after the fascination over Fruit Dealer's keyboard (found this site from teamliquid ^^) and I've pretty much settled on a Filco with Cherry Brown switches. The only problem is that the only ones I can find have a US layout. I'm from the UK but I wouldn't mind adjusting to a US layout, except for 1 key.
This: ¬
On US keyboards, you can't do this without an alt code as far as I know. I'm sure you all know this since you're keyboard pros but it's where the tilde key is on US keyboards as far as I know. My question is, if I got a US keyboard, could I get this key back somehow? Could I map the tilde key to show ¬ or something?
Thanks
Offline keyboardlover
« Reply #1 on: Wed, 20 October 2010, 08:57:11 »
I think this is what you're looking for.
Offline Scottyyy
« Reply #2 on: Wed, 20 October 2010, 09:10:47 »
ooo, very nice. :)
So that's the main problem out of the way. Now for a similar, smaller problem - can I add a play/pause button to one these Filco's? I think I read a few days ago about some software that can do it, but I can't find it. I just need a play/pause button for foobar2000, then the Filco would be perfect.
Thanks man.
Offline Lanx
« Reply #3 on: Wed, 20 October 2010, 09:16:55 »
Quote from: Scottyyy;236321
This: ¬
Hmmm question, what is the UK tilde called?
Offline Viett
« Reply #4 on: Wed, 20 October 2010, 09:21:27 »
Keyboards: FKBN87MC/NPEK, Dell AT101W (Black), IBM Model M 1391401 (91) x 2, Deck 82 Fire, Cherry MX8100 (Clears), Siig Minitouch
Layouts: Colemak (100WPM), QWERTY (100WPM) -- Alternative Layouts Review
Offline zefrer
« Reply #5 on: Wed, 20 October 2010, 09:23:26 »
Change keyboard layout to English UK. Done.
~ is now ¬
Offline Scottyyy
« Reply #6 on: Wed, 20 October 2010, 09:24:21 »
Quote from: Lanx;236335
It's still a tilde. The key is just over on the right side of the keyboard to the left of the enter key.
Quote from: zefrer;236339
~ is now ¬
Really? o.o
Offline zefrer
« Reply #7 on: Wed, 20 October 2010, 09:29:55 »
Yes. I use the reverse, UK keyboard with US layout.
My ¬ key prints ~.
I'm curious tho, do you actually use that character? It's part of the EBCDIC layout which is not even used anymore AFAIK. (Think IBM mainframes with punch cards).
« Reply #8 on: Wed, 20 October 2010, 09:32:14 »
Quote from: ripster
Good luck getting a Cherry Brown.  They are out of stock everywhere.
The link I posted is in stock @ The Keyboard Company.
Offline Kairxa
« Reply #9 on: Wed, 20 October 2010, 09:38:02 »
Quote from: zefrer;236343
For this: (¬_¬")
Offline Scottyyy
« Reply #10 on: Wed, 20 October 2010, 09:41:18 »
Quote from: Viett;236338
AutoHotkey should be able to do it, if you're running Windows.
http://www.instructables.com/id/Keyboard-Media-Controls-for-Windows-with-AutoHotKe/
Thank you sir
My ¬ key prints ~.
Oh, awesome. That's even better.
Thanks
Quote from: Kairxa;236350
For this: (¬_¬")
Exactly ;)
Offline Scottyyy
« Reply #11 on: Wed, 20 October 2010, 09:45:03 »
Quote from: ripster;236356
CopyPasta
I use it far too often to copy/paste it. :p
Offline zefrer
« Reply #12 on: Wed, 20 October 2010, 10:11:16 »
For this: (¬_¬")
Haha thanks, got a laugh out of that :heh: I've always used -_-" and similar.
Offline 8_INCH_FLOPPY
« Reply #13 on: Wed, 20 October 2010, 20:00:10 »
Getting a particular type of keyboard seems like quite a bit of effort to go to...
If you use it that often, you should use macros for it.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
