Author Topic: [IC] Magnum65 - GB Live!  (Read 14086 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Fri, 08 March 2024, 04:25:57 »
GB NOW LIVE!
Magnum 65
by CaryWorks
Post edited by ClickClackIO
Index
- Intro
- Design
- Structure + Kit
- Build Components + Layout
- Functionality
- Colorways
- Packaging
- Pricing and Vendors
Intro
The Magnum 65 is a unique keyboard brought to you by CaryWorks which is inspired by the "Magnum" revolver. Magnum65 is a 65% dual-mode Bluetooth keyboard comprising of 40+ components and featuring a gasket structure.
We are aware of the traction and massive interest in this keyboard and we are delighted to be able to bring it to the international market!
Design
The Magnum 65 as the name suggests is inspired by the theme of the classic revolver. The revolver cylinder is not purely for looks, it is a piece of engineering art! The cylinder is redesigned into the weight, consisting of 11 components and 8 connectors, retaining the cylinder's ability to rotate; coupled with the detachable bullets, capturing the essence of its rotating motion.
The revolver's quick change magazine is added on the side of the keyboard as an accent, consisting of a base and 6 bullets, making it a beauty from all angles.
Structure & Components
The design overview of the Magnum 65:
●   The design theme revolves around the revolver, featuring a unique ratchet structure for the cylinder counterweight and a side-mounted magazine design.
●   Incorporates a Gasket structure with silicone cushioning and spring positioning plate for a softer keystroke feel. The exterior boasts a screw-less design.
●   Supports 4-channel Bluetooth, enabling connection to 4 devices with rapid switching capability.
●   Features an RGB indicator light array.
What the Magnum 65 kit includes:
Main:
●   Upper case;
●   Plate;
●   Base;
●   Side-mounted magazine (with 6 bullets);
●   Battery, battery cover plate,
●   Badge;
●   Distributed silicone grains for indicator lights (4 pieces);
●   Foot pads (4 sets of 2).
Weight:
●   Base;
●   Cylinder;
●   Bearings;
●      Spring plates;
●   Bullets (6);
●   Bullet securing rubber rings;
Locking mechanism.
PCB:
●   Bluetooth dual-mode PCB;
●   Power board;
●   Lighting board;
●   Aluminum alloy spring structure plate;
●   Poron switch spacer;
●   IXPE switch shims;
●   Case Foam
Layout:
Functionality
MAGNUM 65 is a dual-mode keyboard that supports 4-channel Bluetooth connections. The current pairing and battery status can be quickly determined through indicator lights.
●   Battery Indications:
FN + P: Displays the current remaining battery level.
            Low battery warning: Red flashing indicates low battery when the battery is insufficient.
●   Charging indicator:
Upon connection, it automatically enters charging mode, displaying the charging indicator light effect.
●   Bluetooth pairing:
Long press FN + Z/X/C/V to respectively pair with Bluetooth channels #1, #2, #3, #4. The corresponding indicator light flashes blue until pairing is successful.
●   Bluetooth connection:
Short press FN + Z/X/C/V to respectively connect to Bluetooth channels #1, #2, #3, #4. The corresponding indicator light flashes green until the connection is successful.
●   Normal mode:
RGB enabled, with various preset RGB effects and monochrome effects (colors can be customized via VIA).
RGB disabled, all lighting groups turned off.
*The above lighting effects will override the normal RGB effects.
Colorways
The initial release includes three colors: Desert Yellow, Moonlight Silver, and Shadow Black.
Desert Yellow applies a spray painting process, while Moonlight Silver and Shadow Black apply an anodizing process.
Desert Yellow - Spray Painted
Moonlight Silver - Anodized
Nightshade Black - Anodized
Additional Photos:
Pricing and Vendors
Pricing: TBD
Vendors: Worldwide: ClickClackIO
Packaging
To stay within the "military" theme, a military-style case has been designed. The aluminum portable case houses the Magnum 65 in a "laying down" configuration with the lower section of the case acting as the storage unit for the accessory pack which will be used to store keycaps.
Q&A
Q: Can the left wheel behind the kit move?
A: The magazine wheel at the back is designed to be movable. It achieves a ratchet effect through customized pawls and bearings, allowing for a unidirectional tactile rotation.
Q: Are the kit colors fixed combinations?
A: The official configurations will be fixed, but participants in the pre-order group can additionally purchase counterweights for the left wheel and side magazines.
Q: Are there any other options for the plate?
A: For the in-stock sale, the default configuration includes a hollowed-out aluminum plate. However, the pre-order group buy will offer alternative plate options (with blueprints for non-flex cut plate).
Q: Is the PCB flex-cut?
A: The initial release will feature a default with a flex-cut design. However, the pre-order group buy will provide an option for non-flex cut.
Join ClickClack’s Discord for latest update, discussion, questions:
Fill in Interest Check Form:
Follow ClickClack's IG for other new projects:
« Last Edit: Thu, 28 March 2024, 09:21:20 by ClickClack.io »
Offline keepoto
  • HHKB top for TKL pls
Re: [IC] Magnum65
« Reply #1 on: Fri, 08 March 2024, 05:23:22 »
Dank stuff 100% would buy if hhkb
Offline vhaarr
Re: [IC] Magnum65
« Reply #2 on: Fri, 08 March 2024, 08:35:20 »
Yeah, I have another criterion as well though - I would buy this if it was 60% hhkb and the revolver was on the left side facing up, so I could fiddle with it with my left hand lol :-P I realise this would make the keyboard as wide as a TKL at a minimum but I dont care!
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Re: [IC] Magnum65
« Reply #3 on: Fri, 08 March 2024, 12:23:13 »
That Weight design is a real looker. GLWIC
Sent from my Pixel 8 Pro using Tapatalk
Offline kolxy
Re: [IC] Magnum65
« Reply #4 on: Fri, 08 March 2024, 17:09:44 »
What's the front height and typing angle?
Offline Bokehhbob
Re: [IC] Magnum65
« Reply #5 on: Fri, 08 March 2024, 17:20:50 »
Please no flex cuts in the plate or pcb.
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] Magnum65
« Reply #6 on: Fri, 08 March 2024, 19:23:59 »
ain't no way this thing is gonna make it past tsa
    • clickclack.io
Re: [IC] Magnum65
« Reply #7 on: Sun, 10 March 2024, 08:47:03 »
Yes, we will add the uncut plate option during GB.
Offline Nevrest
Re: [IC] Magnum65
« Reply #8 on: Sun, 10 March 2024, 11:10:24 »
WOW this design has some insane attention to detail. Really like the multipart weight.
Reminds me a bit of the weight on the Magic3 boards, love it!
Offline azhdar
  • Praise the AZERTY god
Re: [IC] Magnum65
« Reply #9 on: Mon, 11 March 2024, 16:51:47 »
You need a split left shift if you want a ISO support btw.
Azerty Propagandiste
Offline alose
Re: [IC] Magnum65 - GB Live!
« Reply #10 on: Mon, 15 April 2024, 18:53:31 »
I am assuming no QMK?  Not spending money on another keyboard with QMK.
