Author Topic: [IC] GMK CYL OG Extensions | GB July 15 - Aug 12  (Read 38632 times)
Offline VXQN
Re: [IC] GMK CYL R4 OG
« Reply #50 on: Fri, 24 May 2024, 03:24:34 »
Definitely in for a set of beige. Wish there was a text option for the winkeys but I get that that's not the point of the set...
Offline busytimmy
« Reply #51 on: Tue, 04 June 2024, 20:24:51 »
Thanks everyone for your patience.
Stay tuned for some more changes here. WoB kitting is back on the menu and we are also including a Macros kit as it makes sense to run one in this GB.
Topic and renders will be updated in the coming days, along with tentative GB dates  :thumb:
Offline chigi22
« Reply #52 on: Tue, 04 June 2024, 21:29:14 »
Just when I thought this couldn't get any better...  :cool:
Offline VXQN
« Reply #53 on: Wed, 05 June 2024, 03:12:01 »
You absolutely love to see it. I've been waiting for WoB/Beige macros for so long, thank you!
Offline stomaha
« Reply #54 on: Wed, 05 June 2024, 20:25:19 »
Amazing. I’m in big.
Offline busytimmy
Re: [IC] GMK CYL OG Extensions
« Reply #55 on: Sat, 08 June 2024, 18:48:24 »
*topic renamed*
new renders, change log updates, etc  :thumb:
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #56 on: Sat, 08 June 2024, 23:07:03 »
*topic renamed*
Damn the macro kits are really cool. Really good addition timmy who is busy.
Would probably be down for wob and maybe dolch for both the macros and r4 kit now (mainly because of mx hhkb support lol)
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Fraaaan
« Reply #57 on: Sun, 09 June 2024, 04:58:02 »
Third time's the charm!
Offline CoolPenguin1
« Reply #58 on: Sun, 09 June 2024, 10:12:26 »
I'm assuming this is just a render error but double zero shouldn't have a insert sublegend.
Offline crowcrowcrow
« Reply #59 on: Sun, 09 June 2024, 12:32:36 »
please add xbox backspace before its too late bro please i beg you im actually begging i need it so bad please
Offline konstantin
  • Formerly constexpr
« Reply #60 on: Mon, 10 June 2024, 09:34:10 »
I believe the second M1 key is unnecessary in the macro kits.
Offline VXQN
« Reply #61 on: Mon, 10 June 2024, 11:36:42 »
I vote to keep it, to allow that kit to be used on two boards — One with a single column, one without.
Offline busytimmy
« Reply #62 on: Tue, 11 June 2024, 18:53:56 »
Well caught, thank you. Renders are being updated  :thumb:
Offline konstantin
« Reply #63 on: Wed, 12 June 2024, 20:32:35 »
Makes sense :thumb:
Offline offbrandbiscuit
« Reply #64 on: Sat, 22 June 2024, 08:08:35 »
ICON WINDOWS KEYS LFG!!!!!
i like fire trucks and moster trucks
Offline AJM
« Reply #65 on: Tue, 25 June 2024, 08:57:03 »
Very interested in Macro kits!!  :thumb:
Offline busytimmy
« Reply #66 on: Fri, 28 June 2024, 02:15:38 »
GB Mid July  :thumb:
Offline AJM
« Reply #67 on: Fri, 28 June 2024, 03:02:49 »
It's a bit late and I'm probably the only one - but I would like it, if a scooped numpad 5 key would be included in the OG Extensions. AFAIC OG sets always have a dotted 5, but scooped F and J.
Offline mcmcmc
« Reply #68 on: Fri, 28 June 2024, 22:20:25 »
macros, i love you  :-*
Offline stomaha
« Reply #69 on: Sat, 29 June 2024, 06:40:47 »
Macros, i love you too
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #70 on: Sat, 29 June 2024, 13:19:54 »
While you are at adding more kits, consider adding full icon mod kits for all these colorways. Also including OG XBOX backspace and purse caps lock.
Like the first publicly run GMK keycap sets in 2013-2016. For example Dolch R1, Burgundy R1, Classic Retro, Cyrillic, 9009 R1 and White on Black Icon Pack.
Look here: https://matrixzj.github.io/
Just to re-iterate what I have tried to promote earlier as did others in this GeekHack thread.
« Last Edit: Sat, 29 June 2024, 13:22:32 by twitchytheinsideman »
Offline jay6889
« Reply #71 on: Sun, 30 June 2024, 12:53:17 »
Please add GMK muted as well 😂
Offline busytimmy
« Reply #72 on: Mon, 01 July 2024, 21:07:18 »
Sorry folks, kitting is final. GB thread soonTM :thumb:
Offline AMZ
« Reply #73 on: Mon, 01 July 2024, 22:34:16 »
Is this Extensions works only for GMK Hineybeige, GMK Dolch R5 and GMK WOB ?
Offline iamtragic
« Reply #74 on: Sat, 06 July 2024, 05:12:15 »
Note: Windows and Menu keys will be manufactured in UV-print
Is this a recent change or is my memory fading? Surprised there aren't any R4 moulds available for the retro winkey.
Offline busytimmy
« Reply #75 on: Sun, 07 July 2024, 19:39:40 »
They'll be made with UV print. No change.
Offline VXQN
Re: [IC] GMK CYL OG Extensions | GB July 15 - Aug 12
« Reply #76 on: Wed, 10 July 2024, 03:11:46 »
Can't believe this (GMK Macros) is finally happening. Thanks for all your hard work!
Offline extrapriusplease
    • All my links
« Reply #77 on: Thu, 11 July 2024, 16:43:27 »
novel keys hype wooow!!!
Offline amorino
« Reply #78 on: Fri, 12 July 2024, 00:50:00 »
This is great, good luck!
Offline Jampot_298
« Reply #79 on: Fri, 12 July 2024, 02:42:08 »
Yessssss Timmy! I'm in.
Offline NoWrinkles
« Reply #80 on: Sat, 13 July 2024, 13:39:28 »
Good stuff. In for Beige OG extensions and Beige and WoB Macros
Offline busytimmy
Re: [IC] GMK CYL OG Extensions | GB is LIVE!! | July 15 - Aug 12
« Reply #81 on: Tue, 16 July 2024, 00:56:46 »
« Last Edit: Tue, 16 July 2024, 18:03:01 by busytimmy »
