Author Topic: ZOWIE Celeritas  (Read 3024 times)
Offline tonyklo
ZOWIE Celeritas
« on: Fri, 22 October 2010, 06:04:57 »
http://www.iqmore.idv.tw/2010-bfparty-zowie-celeritas-mechanical-gaming-keyboard
I just saw this earlier..and i talked to someone from Zowie ...
they told me it features a "repeat rate" thing... that's supposed to make your "duck-jump" and "wasd" movement register even faster...
anyone know what "repeat rate" is ? lol  [ u can see on the F keys]
overall, it looks like a really solid keyboard, can't wait !
also, in "gaming mode", the Window key becomes the "ctrl" key
-brown switch in this one
« Last Edit: Fri, 22 October 2010, 06:17:28 by tonyklo »
Offline Moogle Stiltzkin
ZOWIE Celeritas
« Reply #1 on: Fri, 22 October 2010, 06:11:00 »
The led lighted keys sorta look like the Ducky 9008's.
I'm also curious what this repeat rate thing is :/
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline Kairxa
ZOWIE Celeritas
« Reply #2 on: Fri, 22 October 2010, 06:20:04 »
Repeat rate? Isn't it something controlled by OS usually?
You know, like how many FFFFFFFFFFFFFF that you can type in one second.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
ZOWIE Celeritas
« Reply #3 on: Fri, 22 October 2010, 08:45:08 »
Quote from: ripster;237188
The RETURN OF TURBO MODE!
Yep, almost seems like it. '286s would be proud.
Repeat rate indeed is the rate at which characters will come out when you keep a key down. The specifics are somewhere in the IBM PS/2 keyboard docs, but I think the maximum normally is like 32 or 30 characters a second. However, there is no reason why a board shouldn't be able to do more if so desired - you merely have to implement a way to tell the board to use a non-standard repeat rate. Back in the day of the 286, this was a "Turbo" key.
Offline tonyklo
ZOWIE Celeritas
« Reply #4 on: Fri, 22 October 2010, 09:08:26 »
ya i think the OS caps the maximum at like 30
and this keyboard is gona let u go even higher i think
Offline SmallWalrus
ZOWIE Celeritas
« Reply #5 on: Fri, 22 October 2010, 09:56:00 »
The L shaped enter key did killed it for me though :(
The Ducky keyboard community mass order thread
Get one set of keycaps free for a limited time only! :)
Offline phate408
ZOWIE Celeritas
« Reply #6 on: Fri, 22 October 2010, 16:04:45 »
Quote from: ripster;237228
Tuuuuurrrrbbbbooooooo!
Ah man, it's been a while since I've had a computer with one of those.
-Das Keyboard Model S Professional Silent
-IBM Model M 82G2383 (Lexmark 1996)
-Compaq MX 11800
Offline keyb_gr
  • Cherrified user
ZOWIE Celeritas
« Reply #7 on: Fri, 22 October 2010, 16:54:49 »
Dang, sixty's pics of the KB-5170 are down, and I can't find any others :(
Only a permanent URL is a good URL.
EDIT:
Original board from "Rabbit 286" portable.
« Last Edit: Sun, 24 October 2010, 14:49:10 by keyb_gr »
Offline 8_INCH_FLOPPY
ZOWIE Celeritas
« Reply #8 on: Fri, 22 October 2010, 17:00:34 »
I remember reading about those, but what I don't remember is if the  turbo button make the processor faster, or slower, when it was depressed?  I found a Pentium I with one of those Turbo buttons, and I haven't noticed a difference in performance either way.
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
