Advanced search
it's a keyboard thing
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Interest Checks
(Moderator:
Signature
[IC]Hiexa V65-Ball Catch Magnetic Connector Tri-mode Full CNC Custom Keyboard
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [IC]Hiexa V65-Ball Catch Magnetic Connector Tri-mode Full CNC Custom Keyboard (Read 8649 times)
Hiexakey
Thread Starter
on:
Thu, 25 April 2024, 22:13:16 »
Hello everyone,
This is Hiexa Key. We are glad to meet you here. Today, we are going to introduce our first custom keyboard - the Hiexa V65.
For the production
100% fully CNC finish, which allows us to better control quality and improve the craftsmanship of the custom keyboard!
For the design
we have adopted a simple and atmospheric design language so you can enjoy it for a long time and experience the purely customized keyboard!
For the configuration
Hiexa V65 adopts a tri-mode HS PCB, which supports VIA & QMK, customized ball catch structure, magnetic connector assembly process, and other configurations.
Render Gallery
Midnight Purple-Mirror Weight Midnight Purple-Brushed Weight
Black-Mirror Weight Black-Brushed Weight
Ice Blue-Mirror Weight Ice Blue-Brushed Weight
Silver-Mirror Weight Silver-Brushed Weight
Pink-Mirror Weight Pink-Brushed Weight
Latte-Mirror Weight Latte-Brushed Weight
Avocado-Mirror Weight Avocado-Brushed Weight
Design
Front design
We adopts a simple and practical design language.
Side design
The line-cutting technique makes the side profile more design-oriented and customized.
Back design
We used the case's contour to echo the weight balance lines, creating an elegant visual experience between the weight and the bottom case.
Structure
Ball Catch Structure
We have adopted a suitable ball catch for the keyboard case, which can be symmetrically distributed on the shell.
Magnetic Connector
Able to simplify the assembly process.
We customized and opened molds for the fixed silicone at both ends of the daughter board,
which were designed with limit points to stabilize the inner liner connection.
3 in 1 Mount
It can support PCB GASKET, Plate GASKET, and TOP mount. You can customize your keyboard structure.
Anti-collision silicone
it avoids the hard contact between the top and bottom cases when assembled, significantly reducing the case's resonance and hollowness.
Typing Sound
Tri-mode HS PCB
----wired, Bluetooth 5.0, and 2.4G mode.
Support QMK/VIA
Support multiple layout
Include 4400MHA capacity battery
Default Plate
----Non-flex cut POM
Foam
We adopt the mature scheme which verified by the market:
PORON plate foam + IXPE foam + EPDM case foam and PET insulating foam.
Color Option and Finish
Case
Seven colors and two finishes
Anodized Case: Midnight Purple, Black, Ice Blue, Silver
Glitter Spray-coated Case: Pink, Latte, Avocado
Weight
Three colors and two finishes
Mirror PVD Weight: Gold, Silver,Black
Brushed PVD Weight: Gold, Silver,Black
Default Specification
Typing angle: 6.5°
Front height: 18.6mm
Front length and width: 320mm*115mm
Support PCB stabilizers
Weight
Before assembly:1260g
After assembly:1580g
Price
We are sure the price will be very competitive. You can make a guess first. We will update you in future posts.
Vendor
We are looking for vendors now. If you are interested, please get in touch with us. We can discuss more details.
And we very welcome customers giving us recommendations about the vendor you are reliable in your local market.
Reviewer
The prototypes are ready to ship for review. If you are interested, please contact us to discuss the details of the collaboration.
IC Form
Please fill out the IC form to share your thoughts with us. It means a lot to us.
Discord
Join our official Discord for updates and Big Giveaway Promo.
Thank you so much for your time.
Best Regards
HiexaKey
Last Edit: Mon, 20 May 2024, 05:10:01 by Hiexakey
Logged
Discord invite link:
https://discord.com/invite/QMCDtsEJAA
argentstonecutter
Greetings, programs!
Re: [IC]Hiexa V65-Ball Catch Magnetic Connector Tri-mode Full CNC Custom Keyboard
Reply #1 on:
Sat, 15 February 2025, 02:43:59 »
Where do you have your source code repository? I looked for it on Github but couldn't find it.
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
Interest Checks
(Moderator:
Signature
