Advanced search
it's a keyboard thing
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
NEW USERS, READ
THIS!
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Interest Checks
(Moderator:
Signature
[IC]Hiexa V75-Full CNC Ball Catch Magnetic Connector Tri-mode Custom Keyboard
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: [IC]Hiexa V75-Full CNC Ball Catch Magnetic Connector Tri-mode Custom Keyboard (Read 7910 times)
Hiexakey
Thread Starter
on:
Sat, 27 April 2024, 20:05:50 »
Hello everyone,
This is Hiexa Key again. Today, we are going to introduce our second custom keyboard - the Hiexa V75.
For the production
100% fully CNC finish, which allows us to better control quality and improve the craftsmanship of the custom keyboard!
For the design
we have adopted a simple and atmospheric design language so you can enjoy it for a long time and experience the purely customized keyboard!
For the configuration
Hiexa V75 adopts a tri-mode HS PCB, which supports VIA & QMK,
customized ball catch structure, magnetic connector assembly process, and other configurations.
Render Gallery
Midnight Purple-Mirror Weight Midnight Purple-Brushed Weight
Black-Mirror Weight Black-Brushed Weight
Ice Blue-Mirror Weight Ice Blue-Brushed Weight
Silver-Mirror Weight Silver-Brushed Weight
Pink-Mirror Weight Pink-Brushed Weight
Latte-Mirror Weight Latte-Brushed Weight
Avocado-Mirror Weight Avocado-Brushed Weight
V75 Avocado Prototype
Design
Front design
we designed an RGB logo in the function area.
The 75% layout keyboard already provides most of the keys for daily use or work.
The RGB logo allows you to relax in the RGB atmosphere and puts you in a good mood.
Side design
Still used the line-cutting technique to make the side profile more design-oriented and customized.
Back design
we adopted the line combination on the V75 weight,
using the CNC process to cut the stainless steel weight into lines to create a high-level texture.
Structure
Ball Catch Structure
We have adopted a suitable ball catch for the keyboard case, which can be symmetrically distributed on the shell.
Magnetic Connector
Able to simplify the assembly process.
We customized and opened molds for the
fixed silicone
at both ends of the daughter board,
which were designed with limit points to stabilize the inner liner connection.
3 in 1 Mount
It can support PCB GASKET, Plate GASKET, and TOP mount. You can customize your keyboard structure.
Anti-collision silicone
It avoids the hard contact between the top and bottom cases when assembled,
significantly reducing the case's resonance and hollowness.
Silicone column
We have designed six specialized silicone columns around the bottom case to prevent scratches and
scuffs when you quickly disassemble the keyboard.
Typing Sound
Tri-mode HS PCB
----wired, Bluetooth 5.0, and 2.4G mode.
Support QMK/VIA
Support multiple layout
Include 4400MHA capacity battery
Default Plate
----Non-flex cut POM
Foam
We adopt the mature scheme which verified by the market:
PORON plate foam + IXPE foam + EPDM case foam and PET insulating foam.
Color Option and Finish
Case
Seven colors and two finishes
Anodized Case: Midnight Purple, Black, Ice Blue, Silver
Glitter Spray-coated Case: Pink, Latte, Avocado
Weight
Three colors and two finishes
Mirror PVD Weight: Gold, Silver,Black
Brushed PVD Weight: Gold, Silver,Black
Default Specification
Typing angle: 6.5°
Front height: 18.6mm
Front length and width: 320mm*139.2mm
Support PCB stabilizers
Weight
Before assembly:1695g
After assembly:1950g
Price
We are sure the price will be very competitive.
You can make a guess first. We will update you in future posts.
Vendor
We are looking for vendors now.
If you are interested, please get in touch with us. We can discuss more details.
And we very welcome customers giving us recommendations about the vendor you are reliable in your local market.
Reviewer
The prototypes are ready to ship for review.
If you are interested, please contact us to discuss the details of the collaboration.
IC Form
Please fill out the IC form to share your thoughts with us. It means a lot to us.
Discord
We welcome you to join our server for faster updates and discussion. We may have some surprises for you.
Thank you so much for your time.
Best Regards
HiexaKey
Last Edit: Mon, 20 May 2024, 05:11:07 by Hiexakey
Logged
Discord invite link:
https://discord.com/invite/QMCDtsEJAA
PrizeOcelot5911
Re: [IC]Hiexa V75-Full CNC Ball Catch Magnetic Connector Tri-mode Custom Keyboard
Reply #1 on:
Mon, 29 April 2024, 22:41:58 »
So far everything looks great, looking forward to announcing the price
Logged
Bokehhbob
Reply #2 on:
Thu, 02 May 2024, 19:00:19 »
invite link for the discord is invalid, was going to msg you about possible review collaboration
Logged
morara8
Reply #3 on:
Mon, 03 June 2024, 04:02:37 »
I'll take a box pink virgo
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
Interest Checks
(Moderator:
Signature
