Author Topic: Need help finding gold color case  (Read 4262 times)
Offline Exquite
  • GeekAnubis
« on: Sun, 28 April 2024, 12:55:55 »
Hi GH, I just want to ask if anyone knows any Alu keeb with a gold color version? I'm trying to find a matching case for my Aluvia set but the rose gold color is a bit the same shade for me so I have tried to find the gold-yellow color one but I don't find any.
I'm a Color lover and a designer.
Offline Rhienfo
  • GOTHETIGES
Re: Need help finding gold color case
« Reply #1 on: Sun, 28 April 2024, 19:07:23 »
it's pretty hard to find like gold colourways for boards.
I remember the rama thermal had a gold one (but that's mostly because rama messed up the original colour which was supposed to be matched to olivia actually, it was the rosa colourway) I guess that's an option, but never buy from rama directly unless you want to start a money pit.
You could always cerakote, there is a probably a cerakote option for you as well.
Offline lampmk
  • box art peddler
« Reply #2 on: Sun, 28 April 2024, 22:57:06 »
Neo80 has a neat champagne color.
My collection -
Ovinnik - Spyder TKL - FMJ TKL - Keycult 1/60 Raw - Lin Whale - Duck Lightsaver V1
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Sun, 28 April 2024, 23:28:04 »
Yeah the Neo80 champagne color does look good & should give OP what he is looking for. I was gonna say the Ouro colorway that was done on a few Rama boards would be another one. I got a Jules in it & it came out way more goldish than brown.
307660-0
Then another one that came to my mind was the goldish color Hiney used on some of his boards. Can't remember the name of it I think the RAL was called beige champagne or something along those lines. It should pair well with Aluvia.
307662-1
The last one I was thinking was the goldish color the Aaru TKL & 65 came in.
307664-2
The Neo80 would probably be your best bet for price & availability, any of the other boards I mentioned would have to be gotten 2nd hand.
« Last Edit: Sun, 28 April 2024, 23:35:20 by Rob27shred »
Offline Rhienfo
  • GOTHETIGES
« Reply #4 on: Mon, 29 April 2024, 01:27:57 »
Ah yeah those are better options Rob depending on your price range, neo80 is a great budget board.
Offline Exquite
  • GeekAnubis
« Reply #5 on: Wed, 01 May 2024, 10:17:36 »
The neo80 looks clean but oh my, the ouro colorway looks fresh as gold!! Thanks man!!
Offline erretter
    • My Merch Shop
« Reply #6 on: Sun, 05 May 2024, 06:01:26 »
Just wanted to add the Laneware 67. I build this for my wife 2 years ago. and it is great!
Recently I heard that Laneware has abondoned his shop and is not shipping anything, despite the store still beeing online and showing in stock.
However these are rumors. I don't know how true or not this is. Better do some research.
