Author Topic: [IC] Hiexa V80&VPad----Ball Catch Magnetic Connector Tri-mode Custom Keyboard  (Read 5465 times)
Offline Hiexakey
    • Hiexakey Official Website
Hello again, everyone!
Hiexa Key here once more, delighted to introduce our third and fourth custom keyboards - the Hiexa V80 and VPad.
For the production
100% fully CNC finish, which allows us to better control quality and improve the craftsmanship of the custom keyboard!
For the design
we have adopted a simple and atmospheric design language so you can enjoy it for a long time and experience the purely customized keyboard!
For the configuration
both the Hiexa V80 and VPad feature a tri-mode HS PCB, supporting VIA & QMK, customized ball catch structure, magnetic connector assembly process, and other configurations.
Hiexa V80 and VPad Midnight Purple Prototype
V80 Render Gallery
Midnight Purple-Mirror Weight        Midnight Purple-Brushed Weight
Black-Mirror Weight        Black-Brushed Weight
Ice Blue-Mirror Weight        Ice Blue-Brushed Weight
Silver-Mirror Weight        Silver-Brushed Weight
Pink-Mirror Weight        Pink-Brushed Weight
Latte-Mirror Weight        Latte-Brushed Weight
Avocado-Mirror Weight        Avocado-Brushed Weight
V80 Design
Front design
We've installed a dot-matrix circular LED light above the arrow keys.
We're not looking to make it overly flashy, instead,
our intention is for the lighting effect to create a soothing atmosphere for your daily use or office environment.
Side design
We've employed dual-cutting techniques on the V80 to enhance its side profile with a more design-oriented and customized look.
Back design
The geometric design elements and rectangular apertures maintain an overall minimalist style,
while complementing the coordinated side contours for a more three-dimensional appearance.
V80 Structure
Supports both WK and WKL layouts.
Ball Catch Structure
We have adopted a suitable ball catch for the keyboard case, which can be symmetrically distributed on the shell.
Magnetic Connector
Able to simplify the assembly process.
We customized and opened molds for the fixed silicone at both ends of the daughter board,
which were designed with limit points to stabilize the inner liner connection.
3 in 1 Mount
It can support PCB GASKET, Plate GASKET, and TOP mount. You can customize your keyboard structure.
Anti-collision silicone
It avoids the hard contact between the top and bottom cases when assembled,
significantly reducing the case's resonance and hollowness.
Silicone column
We have designed six specialized silicone columns around the bottom case to prevent scratches and
scuffs when you quickly disassemble the keyboard.
V80 Typing Sound
Tri-mode HS PCB----wired, Bluetooth 5.0, and 2.4G mode.
Support QMK/VIA
Support multiple layout
Include 4400MHA capacity battery
Default Plate
----Non-flex cut POM
Foam
We adopt the mature scheme which verified by the market:
PORON plate foam + IXPE foam + EPDM case foam and PET insulating foam.
V80 Color Option and Finish
Case
Seven colors and two finishes
Anodized Case: Midnight Purple, Black, Ice Blue, Silver
Glitter Spray-coated Case: Pink, Latte, Avocado
Weight
Three colors and two finishes
Mirror PVD Weight: Gold, Silver,Black
Brushed PVD Weight: Gold, Silver,Black
V80 Default Specification
Typing angle: 6.5°
Front height: 18.6mm
Front length and width: 362.8mm*139.2mm
Support PCB stabilizers
Weight
Before assembly:1912g
After assembly:2181g
VPad Render Gallery
VPad Design
Vpad's exterior design shares similarities with the design aesthetics of the V80.
Front design
Side design
Back design
VPad Structure
Magnetic Connector
3 in 1 Mount
Silicone column
VPad Typing Sound
Support QMK/VIA
Suppout Rotary Knob
Include 800MHA capacity battery
Default Plate
Foam
VPad Color Option and Finish
Case
Weight
VPad Default Specification
Typing angle: 6.5°
Front height: 17.8mm
Front length and width: 91.8mm*134.8mm
Support Plate-Mount Stabilizer
Weight
Before assembly:455g
After assembly:520g
Price
We are sure the price will be very competitive.
You can make a guess first. We will update you in future posts.
Vendor
We are looking for vendors now.
If you are interested, please get in touch with us. We can discuss more details.
And we very welcome customers giving us recommendations about the vendor you are reliable in your local market.
Reviewer
The prototypes are ready to ship for review.
If you are interested, please contact us to discuss the details of the collaboration.
IC Form
Please fill out the IC form to share your thoughts with us. It means a lot to us.
Discord
We welcome you to join our server for faster updates and discussion. We may have some surprises for you.
Thank you so much for your time.
Best Regards
HiexaKey
« Last Edit: Mon, 20 May 2024, 05:11:28 by Hiexakey »
Offline DirtyGingy
I have to say, this doesn't feel very original, but it is nice. I honestly can't say it's a bad thing. I hope the sales go well
