Author Topic: [IC] Nyawice  (Read 22099 times)
Offline hali
    • hali.studio
[IC] Nyawice
« on: Wed, 01 May 2024, 14:29:56 »
heyyyyyyyy
nyawice
if it ends up vaporware i promise it’s not on purpose
intro | pics | specs | availability | updates | faq | misc
intro
This board got cloned twice before I got to release it so I kinda have to write this IC now.
Quote from: hali at 12/23/2021 4:53 PM
ok
guys
hear me out here
catboy
alice
nyawice
Quote from: OJ at 12/23/2021 4:53 PM
no
stop
Quote from: hali at 12/23/2021 4:55 PM
stop me
pics
Renders by dudeship
Colours
final colours may not be representative of those displayed in renders. also the first orange looked kinda weird so i’m gonna pull some strings to make it lighter
Photos
Unbuilt
Built
current revision has no round cherry lip and instead has hg along the front and back as shown in the unbuilt orange proto
Full Album
Videos
Build log by xinxinwong
Soundtest by me
specs
Features
- Alice
- F1 mount but curvy
- F1 size but cute
- Silicone friction fit nose
- Big alu cat ears
- Lots of top engravings
- Round HG/LZ-SE/959 Mini whatever side profile
- Stupid cute heart shaped LEDs
- Cat butt
- “Seamless”, “screwless”
- PCB designed by calliah featuring art by my friend sena
- S1 Unified Daughterboard
- Standard 8 mm Bumpons
Tech Specs
Layout
Alice
Mounting
Leaf Spring F1 Mount[1]
Typing Angle
Switch Compatibility
MX
Front Face Height at Chin
15 mm
Front Face Height at Ctrl Keys
18.229 mm
Adjusted Front Height[2]
19.690 mm
Effective Keyboard Height[2]
23.625 mm
Case Material
6063 Aluminum
Plate Material
5052 Aluminum
Weight Material
Clear coated brass, whichever one DDS uses
Colours
Silver plate and bottom case with pink/orange/lavender top case
Layout
no 2u bar because it makes clip ins weird
availability
idk yet, message me on discord please
Going to preemptively mention that this keyboard will likely not be good for your wallet. I’m personally aiming for under $600 but we’ll see what happens when I get a vendor who knows more about this than me.
updates
May 1st, 2024: IC posted
faq
More colour options?
Maybe? Depends on if DDS doesn’t charge me more and if vendors are cool with more SKUs.
Hotswap?
I’ve given Callie enough money and she will also extort me because she doesn’t want to make it. I highly recommend hitting up a local builder and getting your board millmaxed if hotswap is the route you want to take.
Polycarbonate case/plate?
PC cases kinda scare me after trying to fix warped horses for months. As for plate, I really only see myself offering alu since it works best with the leaf spring.
misc
Socials
Discord | Instagram | Site
Thanks
- Patty for using sugar mommy funds to help me prototype this
- calliah, but I’m still not running the keychain
- @_megrocks for enabling me and creating this
- Hatsune Miku for letting me use her as promotional material even though she’s not even my cat
- Susan and the rest of Mintlodica for using it in a render a couple times and getting me 200 Instagram followers in one day in what was basically a feline orbital strike at my target market
- literally everybody i led on by not doing anything with this
- Sena and Gus for helping with the journey, even if they couldn’t stay the whole way
^ 1. Alu only.
^ 2. Measured at the Control keys and without feet.
Offline hali
    • hali.studio
Re: [IC] Nyawice
« Reply #1 on: Wed, 01 May 2024, 14:30:16 »
reserved
Offline Sleepdealr
  • my name is calliah
    • https://sleepdealer.xyz
Re: [IC] Nyawice
« Reply #2 on: Wed, 01 May 2024, 14:31:41 »
« Last Edit: Sat, 04 May 2024, 01:02:30 by Sleepdealr »
Offline ankit
  • Formerly ankit-sachdeva
Re: [IC] Nyawice
« Reply #3 on: Wed, 01 May 2024, 14:32:01 »
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: [IC] Nyawice
« Reply #4 on: Wed, 01 May 2024, 14:32:01 »
catboy hali at it again, this nice.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline dededecline
    • Linktree
Re: [IC] Nyawice
« Reply #5 on: Wed, 01 May 2024, 14:32:05 »
:3
Offline Patty
  • do u like my cat yes or no
Re: [IC] Nyawice
« Reply #6 on: Wed, 01 May 2024, 14:32:10 »
Take my money
Offline Ella
  • Why is it called an oven
Re: [IC] Nyawice
« Reply #7 on: Wed, 01 May 2024, 14:32:19 »
nya
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
Re: [IC] Nyawice
« Reply #8 on: Wed, 01 May 2024, 14:32:39 »
fire
Offline LMarci
Re: [IC] Nyawice
« Reply #9 on: Wed, 01 May 2024, 14:35:36 »
Nyawice :thumb:
Offline Gtour
  • Just a random guy passionate about keyboards.
Re: [IC] Nyawice
« Reply #10 on: Wed, 01 May 2024, 14:36:17 »
Cute af
Offline NixieType
Re: [IC] Nyawice
« Reply #11 on: Wed, 01 May 2024, 14:38:24 »
Nice car
Offline Pyroo
Re: [IC] Nyawice
« Reply #12 on: Wed, 01 May 2024, 14:40:37 »
car :3
Bunny enthusiast
Offline andromache
Re: [IC] Nyawice
« Reply #13 on: Wed, 01 May 2024, 14:42:57 »
i'm begging someone to let me buy this
Offline TyPo.mk
Re: [IC] Nyawice
« Reply #14 on: Wed, 01 May 2024, 14:47:53 »
UwU so cute UwU
Offline DirtyGingy
Re: [IC] Nyawice
« Reply #15 on: Wed, 01 May 2024, 14:53:11 »
It has a butthole. I approve.
Offline halocantkb
  • Formerly 'shota_irl'
Re: [IC] Nyawice
« Reply #16 on: Wed, 01 May 2024, 15:00:38 »
we're SO back
Offline bluranerd
    • Youtube
Re: [IC] Nyawice
« Reply #17 on: Wed, 01 May 2024, 15:18:03 »
boutta put myself in financial ruin over an uwu nya catboy board
Offline Dazon
Re: [IC] Nyawice
« Reply #18 on: Wed, 01 May 2024, 15:20:43 »
nya. mrow, even.
Offline marshmellohs
Re: [IC] Nyawice
« Reply #19 on: Wed, 01 May 2024, 15:51:37 »
thank you for cooking! yum yum nyawice so good
Offline mr_foggy
  • neue = nope
Re: [IC] Nyawice
« Reply #20 on: Wed, 01 May 2024, 15:53:24 »
I want one
Offline paperassgasket
Re: [IC] Nyawice
« Reply #21 on: Wed, 01 May 2024, 16:02:24 »
:3
Offline nebulazy
  • i liek keybort
Re: [IC] Nyawice
« Reply #22 on: Wed, 01 May 2024, 16:03:30 »
o jeez yet another cat keyboard i don't need but will buy anyway......... (fyi its v cute)
Offline Alvin12356lol
    • zambumon
Re: [IC] Nyawice
« Reply #23 on: Wed, 01 May 2024, 17:48:35 »
nya
Offline Soundtrack
Re: [IC] Nyawice
« Reply #24 on: Wed, 01 May 2024, 20:25:40 »
Meow
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: [IC] Nyawice
« Reply #25 on: Wed, 01 May 2024, 22:18:43 »
kiwi likes this
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
Re: [IC] Nyawice
« Reply #26 on: Thu, 02 May 2024, 04:33:37 »
nyaaaan
Offline LavenderB
  • I believe in unix control supremacy
Re: [IC] Nyawice
« Reply #27 on: Thu, 02 May 2024, 04:59:06 »
A catboy themed hali project? Ugh, it's tempting...
Safa | 1993 UK ISO-DE Model M  | Frog TKL | 3d printed bakeneko | Akko 5075s
Offline crowcrowcrow
Re: [IC] Nyawice
« Reply #28 on: Thu, 02 May 2024, 09:40:01 »
My cat's name is nya. Fire.
Offline Lysol_
Re: [IC] Nyawice
« Reply #29 on: Thu, 02 May 2024, 10:02:12 »
:3
Offline erretter
    • My Merch Shop
Re: [IC] Nyawice
« Reply #30 on: Thu, 02 May 2024, 10:15:29 »
I avoided Alice for the longest time, this thing might actually change that :O
Offline Klexos
Re: [IC] Nyawice
« Reply #31 on: Thu, 02 May 2024, 10:43:54 »
The finest board this hobby has ever seen
Offline ben56k
Re: [IC] Nyawice
« Reply #32 on: Thu, 02 May 2024, 10:46:54 »
interesting face and bottom, every nya keyboard seems promising
Offline Ariella
Re: [IC] Nyawice
« Reply #33 on: Thu, 02 May 2024, 15:28:48 »
I NEEEEEEEEEEEEEED IT
Offline sauvieng
Re: [IC] Nyawice
« Reply #34 on: Fri, 03 May 2024, 01:24:39 »
not a want it's a need.
Offline SmokeySpoon
Re: [IC] Nyawice
« Reply #35 on: Fri, 03 May 2024, 09:32:29 »
What purple keycap set is that? Or is it only a render for the IC.
Offline phurawnc
Re: [IC] Nyawice
« Reply #36 on: Fri, 03 May 2024, 10:10:43 »
i need cat
Offline hali
    • hali.studio
Re: [IC] Nyawice
« Reply #37 on: Fri, 03 May 2024, 16:24:33 »
i'm sorry but it's not real
if you want to run it the theoretical colours are pantone P 98-16 C, 276 C, 4002 C, and GMK MG1
Offline usedchopstick
Re: [IC] Nyawice
« Reply #38 on: Fri, 03 May 2024, 19:18:59 »
Hope someone picks this up, would love to buy
Offline kaitalyn
Re: [IC] Nyawice
« Reply #39 on: Fri, 03 May 2024, 20:29:46 »
car keybord :3
Offline fruitykeeb
    • Storefront
Re: [IC] Nyawice
« Reply #40 on: Fri, 03 May 2024, 21:49:08 »
:3
Offline mcmcmc
Re: [IC] Nyawice
« Reply #41 on: Sat, 04 May 2024, 00:53:06 »
Offline sophv
Re: [IC] Nyawice
« Reply #42 on: Sat, 04 May 2024, 12:10:23 »
ez buy
how can keyboards be real if our eyes aren't real
*bites cherry lip*
Offline Daesya
  • 💜 purple supremacy 💜
    • social mediass
Re: [IC] Nyawice
« Reply #43 on: Tue, 07 May 2024, 05:06:52 »
meow
Offline keepoto
  • HHKB top for TKL pls
Re: [IC] Nyawice
« Reply #44 on: Tue, 07 May 2024, 08:15:43 »
let me on mr hali's wild ride
Offline fortissim2
Re: [IC] Nyawice
« Reply #45 on: Thu, 09 May 2024, 09:26:04 »
Two words: awesome.
Offline soundstage
Re: [IC] Nyawice
« Reply #46 on: Fri, 10 May 2024, 09:34:20 »
This design has character. Nice innovation indeed! Hope to see a TKL version next.
Offline Minisofu
  • Aspiring Keycap Designer
Re: [IC] Nyawice
« Reply #47 on: Fri, 10 May 2024, 10:48:31 »
This is so prettyyyy, would definitely get it if i got the money
Offline Butterbeer
Re: [IC] Nyawice
« Reply #48 on: Fri, 10 May 2024, 17:11:34 »
Excited to see this here in the IC!
Take your time with this one.
Hoping we can all get our hands on one some day!
Re: [IC] Nyawice
« Reply #49 on: Tue, 21 May 2024, 20:44:25 »
Def. in for this board. Hope someone picks it up soon!
