Author Topic: [GB] Pneuma Mk.2/60 - GB concluded, extras available  (Read 13795 times)
Offline antipode-studio
« on: Fri, 03 May 2024, 15:17:35 »
Introduction on the Pneuma from Stef:
The Pneuma is my take on the 60% form factor that I have worked on for the past couple of years. The name "Pneuma" or "πνεῦμα" is a noun used by the ancient Greeks to describe the "Spirit"  or "Soul". It is also used to describe the creative force within humans, a nod to the inspiration I've gotten while designing the board. The board was developed around the design philosophy that a product shall be interesting from three distances: far away, regular usage distance, and up-close.
From afar, the large shapes, soft lines and material finishes invite the user to come closer. Here they can notice the symmetry, balanced weight and design cues like the slightly larger slope of the case that looks like it sucks in the keycaps. Finally, when getting really up-close with the board, tiny details start to stand out like the continuous curvature of the outer edges and the tiny fillets used on the main chamfers to soften the look & feel.
A private GB was held for the Mk.1 design in 2020. It was planned to enter the public GB phase shortly after but was deemed too risky at that point in time due to the pandemic. However, armed with new insights, we improved the Mk.2 in terms of assembly, typing feel, and machinability while staying true to my initial vision for the board.
Changes from the Mk.1:
Mounting changed from poron gasket mounting to o-ring strip gasket mounting.
Plate coverage and stiffness are similar, but gaskets are now removable/replaceable to experiment with different materials and hardnesses.
Overhauled internal construction.
No mid-piece and faceplate but a single bottom piece. This simplifies the complex machining of the Mk.1 design and reduces the number of screws needed to disassemble the board (from 10 to 4) without losing the screwless exterior.
Added internal weight.
To offset the weight from the previously optional stainless steel faceplate/mid-piece in order to increase total weight and cover the daughterboard cable channel.
Introduced Polycarbonate top version.
Due to the new assembly method of the Mk.2, there are no visible screws in the PC top, and all threads remain in the aluminium bottom. The PC top didn't fit the desired design language in the Mk.1 since the screws would be visible.
The design language and ratios have remained the same but refined with continuous curvature on the outer radii, softened edges less prone to damage, and updated logo at the bottom.
Product details:
Specifications:
6.5 degree typing angle
7.5 degree top case angle
Clean seamless construction
23.1mm Adjusted Keyboard Front Height
O-ring strip gasket mount compatibel with 3mm ø cord
6063 Aluminium top/bottom case or option for PC top.
Copper internal weight
Estimated weight: 1.5kg (built)
Compatible with Geon 60% removable rubber feet
QMK/VIA compatible PCB by Martin
What is included:
- Pneuma Mk.2/60 case (top, bottom and weight)
- Standards aluminium ANSI plate
- Solder PCB
- String of O-ring gasket
- Assembly hardware and alignment pins
- Rubber feet
- Antistatic bottom case sheet
- Carrying case with cleaning cloth
- Color combinations and material options available at:
https://www.antipode.studio/collections/pneuma
Plate & PCB:
Default plate compatibility
PCB compatibility
Current sale plans:
- Streams from Alexotos on May 5th and LightningX TBA
- Presale from May 6th till May 12th: Aegis Green and Midnight Purple will be pre-order exclusives color options. WK and HHKB layouts for all colors will also be a pre-order exclusive. Antipode will only stock WKL.
- Antipode exclusive in-stock: 100 planned units
- Price $399 for the kit with, Estimated production timeline of 6-7 months after the end of the presale.
Visuals:
Prototype Photos:
First round of prototypes:
Second round of prototypes:
Case internals:
Typing tests:
First round prototype with Gateron Oil kings on Alu plate:
First round prototype with Sarokey strawberry wines on Alu plate:
Special thanks to:
The Antipode team, for collaborating with me on my personal dream project and offering a level of collaboration unheard of in this hobby.
All buyers and supporters of the Mk.1 Pneuma, for offering great insights for improvement and their long term support for this project ❤️.
« Last Edit: Thu, 16 January 2025, 08:27:53 by antipode-studio »
GB Update - 26.06.2024
- Production are well underway, there are some videos & photos posted on our discord server.
- Carrying cases, cardboard boxes and cloths have completed production an are enroute to our warehouse.
- Gaskets have arrived.
- Alignment pins have arrived.
- ESD film has arrived.
« Last Edit: Wed, 26 June 2024, 05:18:52 by antipode-studio »
Approved :thumb:
Offline emalider
pc top/alu bottom let's go
GB Update - 12.09.2024
Hi everyone!
Stef have received the color samples - Aegis, Elysium, Stoic & Midnight are approved and good!
Stef felt that Spartan(red)  were still not correct, and we have agreed with the manufacturer to re-anodize those tops, expect them to be ready in a few weeks.
We have instructed our manufacturer to ship us all the Aegis, Elysium, Stoic & Midnight units, so that we can get on with the quality control and getting those orders shipped out ASAP.
For the people waiting for their Spartan board/top we want to give you a couple of options:
1: You can wait till we get the colors absolutely correct, hopefully should be with us in 4-8 weeks time, ready to ship to you! I will add a small gift to these orders as a token of appreciation for your patience when we ship them to you.
2: You have the option to change to Aegis, Elysium, Stoic or Midnight, if you want this - reply to your order confirmation mail and we will get it taken care off!
For all others, if you want to add any extra plates, PCB's or gasket packs - reply to your order confirmation e-mail and we'll get it added, same if you need to change the shipping address!
Instock sale will happen once pre-order units have been shipped!
« Last Edit: Thu, 12 September 2024, 05:31:50 by antipode-studio »
Update 10.10.2024:
All orders will be shipped today, pickup by FedEx and DHL tomorrow.
Extras will go live on our website http://antipode.studio on Friday the 11th of October at 1500 CET, there will be a small amount of each SQU available.
Re: [GB] Pneuma Mk.2/60 - Instock sale on the 11th of October at 1500 CET
« Reply #7 on: Thu, 16 January 2025, 08:27:23 »
Hi all,
This GB has now concluded, extras available here: https://www.antipode.studio/collections/pneuma
