Author Topic: [IC] PBTfans - Retro Dark Lights R2  (Read 11508 times)
Offline Jr.Mars
« on: Sun, 05 May 2024, 23:01:44 »
Hi geekhacker,
PBTfans-Retro Dark Lights R2 is coming back!
R2 will come with the translucent keycaps.
Almost same as the "GIFT" of Retro Dark Lights R1.
>>>> Interest Check Form <<<<
- Please help me to fill out this form and provide any feedback that you have.
◎ Inspiration
- The inspiration comes from the Dark Mode of MacOS, and the novelties comes from the window buttons in macOS.
◎ Kitting
- The front legends of R1 num raw will use uv-printing.
- The PBTfans logo and R1 icon novelties will add rainbow glitters.
- The colors on alpha kit are the same as the alpha part on the R1 base kit, which are solid colors(not translucent)
◎ Renders
◎ Metal Keycap (ANSI Enter)
◎ Deskmats
◎ Contact
◎ Information
☆ Manufacturer: PBTfans
☆ Material: ABS material
☆ Production Method: Doubleshot / UV Print
☆ Profile: Cherry profile
Offline Jr.Mars
Re: [IC] PBTfans - Retro Dark Lights R2
« Reply #1 on: Sun, 05 May 2024, 23:02:10 »
reserved
Offline hzh0525
« Reply #2 on: Sun, 05 May 2024, 23:06:14 »
reserved!
Offline EdwardsLau
« Reply #3 on: Sun, 05 May 2024, 23:06:59 »
Added to my must-cop list
Offline markexodia
« Reply #4 on: Sun, 05 May 2024, 23:32:24 »
pbtfans? hmmm
« Reply #5 on: Mon, 06 May 2024, 03:26:14 »
I need it
Offline mr_foggy
  • neue = nope
« Reply #6 on: Mon, 06 May 2024, 05:32:14 »
this set deserved to run with keykobo
Offline blondie
« Reply #7 on: Mon, 06 May 2024, 06:31:13 »
I like these kinds of keys except for the visible divot. Unfortunately there's nothing that can be done about that as it is part of the manufacturing process.
There is no greater knowledge than the knowledge of one's self. There is no greater truth than the truth of moral conviction. And there is no greater keyboard than the one beneath my fingertips.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #8 on: Thu, 27 March 2025, 22:14:27 »
In stock now at KBDfans - https://kbdfans.com/products/pbtfans-retro-dark-lights-r2
They also list of other vendors:
    SE: MaxGaming-MaxFPS AB
    UK:Prototypist Keyboards
    DE:KEYGEM
    USA:Divinikey
    CA:Unikeyboards
    SGP:Ktechs
    JP:Yushakobo
    USA:Mechanical Keyboards,LLC
    KR:GEON
    TW:PNKeyboard
