Author Topic: Other keyboards like the Azeron Cyborg? (similar to DataHands)  (Read 10936 times)
Offline TheWonderAlmighty
The Azeron Cyborg: https://www.tomshardware.com/reviews/azeron-cyborg-compact is an alternative keyboard with an alternative layout where the keys have much lower proximity between each other than a regular one. I wonder if other keyboards like it exist. I know there's the Svalboard inspired by DataHands, but that's way more expensive and has less keys. Also I could easily fail doing the DIY for the Lalboard. I know there's the Svalboard inspired by DataHands, but that's way more expensive. Also I could easily fail doing the DIY for the Lalboard.
Offline wjrii
Re: Other keyboards like the Azeron Cyborg? (similar to DataHands)
« Reply #1 on: Tue, 07 May 2024, 21:23:26 »
They're kind of ALL inspured by the Datahand, right?
Apart from the ones you mentioned, I found a few on DIY and 3D printing communities.  I'm not sure they're all going to have enough keys, but appearances can be deceiving with this sort of design.
https://www.thingiverse.com/thing:4832101
https://hackaday.com/2020/09/23/diy-ergonomic-game-pad-lends-a-hand/
https://www.instructables.com/Azeron-Game-Pad-DIY-Under-35/
If you are willing to approach the same goal with a more conventional solution, try ergo boards with keywells.
