Author Topic: [IC]BHS60—Centennial Classic , Review and try  (Read 4910 times)
Offline SR
« on: Wed, 08 May 2024, 21:51:49 »
Hello everyone, this is B-LAB.
I am the new team leader SR, a former architect.
The first kit I brought was named BHS60, inspired by Bauhaus, which Abbreviations for Bauhaus.
catalogue
1、 Preface
2、 Appearance design
3、 Keyboard information
4、 Q&A
1、 Preface
What is Bauhaus?
The definition of Bauhaus may be perceived by most people as design style, language, academic system, including various buildings, furniture, and so on.
But throughout the entire history of development, Bauhaus should be more of a "spirit".
In the early stage of the design, I referred to many overseas websites, and most of the 60% of the configurations were designed with a minimalist style and pure inner lining to restore the sound of the shaft itself, which coincides with the design concept of this BHS60.
So I adapted to the times and also used stable diffusion, generating a large number of "reference materials" and using them to carry out the design.
①Three layouts can be replaced by changing the bottom cover
②The three-stage layout can adapt to more different styles of keycaps
③Designed with light strips and sufficient height to meet daily use
④The inscriptions are all in the font of Herbert Bayer
307769-1
307771-2
307773-3
307775-4
307777-5
307779-6
307781-7
307783-8
307785-9
307787-10
307789-11
307791-12
307793-13
307795-14
Slope: 8%
Front height: 18mm (excluding foot pads)
Allocation: 60% (WK, WKL, HHKB)
Colors: Beige (beige), RML (mixed light)
Price: TBD
Quantity: 100 sets, futures
Weight: 1.3kg (outer shell only, excluding inner liner)
Structure: GAS
Positioning board: PC slotted, FR4 slotted, AL non slotted (one standard)
PCB: 1.2mm single-mode slotted hot swappable, 1.6mm single-mode non slotted welding (welding plate must meet MOQ standards)
Sound package: PORON sandwich cotton, IXPE shaft bottom pad, PORON bottom cotton
Surrounding: BHS60 metal block
If you are interested, welcome to join our discord: https://discord.gg/dBJpgpnP
« Last Edit: Wed, 08 May 2024, 22:35:23 by SR »
Offline rrdaud
Re: [IC]BHS60—Centennial Classic , Review and try
« Reply #1 on: Fri, 26 July 2024, 08:01:11 »
This is gorgeous, how come there's no notes on this?
