Author Topic: keys ain't work  (Read 4685 times)
Offline ZentoBoomin
keys ain't work
« on: Sun, 12 May 2024, 17:43:57 »
hello everyone, recently i bought an aftermarket keyboard from someone else, and idk what kind of specific model for it but all i know its from tecware phantom TKL. short story when i tested it its working and all the lights are lit up, but the f3, 3, e, d, c, and all botttom rows where the space is located (including Arrow keys) is doesn't work. I've tested to jumper the pin but failed because the space doesn't even turned on.
like for example if i connect a wire to the second pin (the one that are connected to diode) in this case alt-right key and connect it to the top row, the key that will activate is v key, and if i more it to the top once more, the f key activate, repeat this step and the key that actived is r, 4, f4.
 I've do the same thing with space but it doesn't work at all. anyone have any idea?, i think its the traces to the space that are messed up but I've checked using multimeter that are all the rows are beeping and the diodes are beeping. any ideas?
Offline The One
Re: keys ain't work
« Reply #1 on: Thu, 23 May 2024, 05:25:31 »
Any suspect on the MCU?
I would map out the matrix to find the columns and rows connection to the MCU. Confirm the matrix from the MCU pins with multimeter. If it works fine maybe the space row and column trace are broken
Offline wjrii
Re: keys ain't work
« Reply #2 on: Fri, 24 May 2024, 18:32:56 »
If you have the budget, and I'm sensitive to the fact that not everyone would, I might recommend letting this one go.  That feels like a lot to be wrong with a 3-pin Outemu hotswap low-profile-case gamer board.  You could get a comparable replacement for about $30, and a hot swap Keychron C3 Pro is out there for under $50.
