Author Topic: Recommend a Keycap Set  (Read 6166 times)
Offline bagger
« on: Tue, 14 May 2024, 03:40:20 »
Hello! I’ve recently gotten into the Hobby and I’ve bought some aftermarket keyboards that don’t have keycaps. I have little eye for aesthetics so I’m more than happy to look at any type of keycaps, no preferences. So I’d love to get y’all’s recommendations! Suggest me a keycap set! (Links would be nice but if not /shrug).
Offline TomahawkLabs
Re: Recommend a Keycap Set
« Reply #1 on: Wed, 15 May 2024, 11:20:49 »
What kinds of profiles do you like? Do you want a second hand, vintage set that may be more unique? What color palettes are you looking for? What boards will they go with? Do you need RGB shine through keycaps?
That being said, my vote is always for a Signature Plastics SA profile keycap in whatever theme fits the board.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline Rhienfo
  • GOTHETIGES
« Reply #2 on: Thu, 16 May 2024, 02:41:52 »
Yeah this question requires a lot more detail for a good answer. But in general if you are starting out I wouldn't reccomend SA because it's more an aquired taste, and for a lot of people it's too high up. I would recommend buying cherry keycaps. JC studio/leekbrothers if you are on a small budget (leekbrothers is the taobao name) and if you have more of a budget a lot of vendors have gmk instock often at discounts if you want to pick them up (Just pick good vendors, in the U.S novelkeys or cannonkeys, in the EU oblotzky is amazing for some reccomendations)
If you do like SA then absolutely go with signature plastics, the quality is very good.
« Reply #3 on: Thu, 16 May 2024, 09:33:59 »
...But in general if you are starting out I wouldn't reccomend SA because it's more an aquired taste, and for a lot of people it's too high up...
This is actually better advice. SA is a very sculpted, very tall profile that I personally love. My spouse hates it and loves their XDA (flat, but textured) Space Cadet set. OEM/Cherry profile would feel more natural to what you are used to typing on (assuming you aren't using a flat/chiclet style keyboard).
SA: Camping
