Author Topic: Why is there no light for 'insert lock'  (Read 9974 times)
Offline 8_INCH_FLOPPY
« on: Sat, 23 October 2010, 21:37:42 »
This rant is the result of me typing over 7 characters without noticing that I had hit the insert key earlier.
Is there any logical justification for the existence of the insidious 'insert' key?
I remember when I first started typing I had to look down at the keyboard in order to  achieve the blinding speed of 10wpm.  There were several times when I went back and erased 5+ minutes of work by bumping the insert key.  Now, that was a long time ago, but I still see novice computer users/typists make this mistake all of the time.  I once saw a guy at the library looking at the monitor incredulously as he typed a letter he was writing.  He froze for a couple of seconds, then started screaming hysterically about bleeping computers bleeping bleep and he literally ran out of the library.  Now, I admit that he was probably mentally unstable, but that doesn't mean that the insert key in its current form is a good idea.
There's still a 'scroll lock' indicator light, and I've never heard of anyone using scroll lock, except rarely with dos.  Why the hell is there not an 'insert lock' indicator light, at least?
Soooo, whatsittherefor?
Notable Switches I have tried:
black cherry, blue cherry, brown cherry, clear cherry, cherry M84, white alps, black alps, cream alps, Monterey blue alps, Fujitsu Peerless, Gateway2000 rubber dome, Keytronic rubber dome, Model M buckling spring, Model F buckling spring, futaba, black space invader
HAPPY HUNTING
Offline HaaTa
  • Master Kiibohd Hunter
  • Kiibohds!
    • http://kiibohd.com
« Reply #1 on: Sat, 23 October 2010, 21:40:08 »
Well, I feel your pain, sorta. In most applications I hate the existence of the Insert key. Not really a problem anymore as I touch type now so I'll notice when I'm replacing.
Now if I'm using vim or a vim enabled editor, I semi-regularly use the Insert to swap between the Insert and Replace modes. But there I usually have a visual display of the mode I am in.
Kiibohd
ALWAYS looking for cool and interesting switches
I take requests for making keyboard converters (i.e. *old keyboard* to USB).
Offline Rajagra
« Reply #2 on: Sat, 23 October 2010, 22:27:31 »
I think overwrite mode is a relic from a bygone age, when the ability to insert text instead of overwriting was seen as something magical and terrifying. I don't see the point of it any more. If you want to overwrite text you can highlight it first and just start typing.
After all, what are the odds that the new text you are typing is exactly the same length of what you are replacing? Quite slim, normally.
The only time I've ever used overwrite mode is for keeping plain text files properly aligned when editing them (ASCII diagrams and similarly aligned text.)
Ever since we lost proper hardware cursors this has caused problems. Get rid of it! I won't miss it.
« Last Edit: Sat, 23 October 2010, 22:29:34 by Rajagra »
Offline Sam
« Reply #3 on: Sun, 24 October 2010, 01:10:22 »
I use the insert key all the time.  Probably dozens of times per day on average.  I would hate a keyboard without it.  It's extremely useful when doing coding, at least for me, as I grew up with it and it's a big timesaver when making updates to code and the need to typeover what's there.  If there was no typeover mode, I'd have to delete the existing text first or after typing the new text.  Not a big deal, but unnecessary keystrokes. If you really don't like it, simply use a key remapper to disable the key or give it some new function.
Offline Fwiffo
« Reply #4 on: Sun, 24 October 2010, 01:56:17 »
The reason there's no insert light is because the state of insert/overstrike is local to applications (or even documents). Compared to e.g. caps lock which is global. In other words, you turn on overstrike mode in Word or something, then switch to notepad, and notepad will still be in insert mode. And then you switch to some other app, and it's not even supported, and then you switch back to word, and it's still in overstrike.
A lot of games use it for camera control for some reason.
You can call me... Keyboard Otaku... or not quite...
Offline ch_123
« Reply #5 on: Sun, 24 October 2010, 03:44:23 »
Some of IBM's older terminals (including the 5251) had an overwrite indicator light on the terminal for exactly this purpose. Why they didn't copy the idea on to the PC is unknown... Possibly because the location on insert on the AT Model F made accidental presses much less likely, and they wanted to preserve the same amount of indicator lights when going from the Model F to Model M.
Either way, modern keyboard manufacturers are far more likely to get rid of, or obscure the insert key than provide a light for the people who use it.
Offline 7bit
  • MX1A-G1DW
« Reply #6 on: Sun, 24 October 2010, 14:59:58 »
Quote from: 8_INCH_FLOPPY;237807
The reason is that Insert is application specific. If you use a decent editor, there will be an indication (something like 'Insert 'or 'Overwrite' or a changed cursor style). Also, there will be a useful Undo-option hidden in the menus.
There exist a lot of programs which don't have an overwrite function at all, like Firefox or XTerm.
Buy key caps here: Round 5
Buy switches here: CherryMX
Offline Rajagra
« Reply #7 on: Sun, 24 October 2010, 15:48:18 »
Good application: Notepad++. Insert mode places vertical cursor between two characters, showing where new characters will go. Overwrite mode places horizontal block cursor beneath the character that will be replaced with the next keystroke.
Bad application: Internet Explorer. Cursor is the same in both modes. Way to go Microsoft!
Offline Shawn Stanford
« Reply #8 on: Mon, 25 October 2010, 06:44:06 »
FYI: There are still tens of thousands of programmers maintaining billions of lines of mainframe code. We need that insert key.
Kevin hit it on the nose: when I hit insert in my terminal, the shape of my cursor changes and I get a caret character in the terminal status line (I also get a 'Caps Lock' indicator).
Leave my Insert and Caps Lock keys alone, please...
The Brat Prince of COBOL
Offline 7bit
  • MX1A-G1DW
« Reply #9 on: Mon, 25 October 2010, 07:12:10 »
Quote from: Shawn Stanford;238323
Caps Lock certainly should be renamed to "Cobol Input".
Offline itlnstln
« Reply #10 on: Mon, 25 October 2010, 07:17:17 »
I use Caps Lock writing SQL as well.  I like my Caps Lock.  I do hate Insert.  In most applications, the cursor changes to a block, so it's easy to tell when it's on.
Offline instantkamera
« Reply #11 on: Mon, 25 October 2010, 07:47:19 »
Quote from: itlnstln;238333
really, why? I agree that, while not GENERALLY required (I guess it depends on your engine), uppercase syntax makes visually parsing SQL that much easier, but that generally only works if you have lowercase tables/columns/indices/variables/etc, otherwise it's all an UGLY WALL OF ALL CAPS. So isn't that a lot of caps lock pressing? Take the (way over simplified) example:
SELECT column FROM table WHERE other_column = 1
Why not just use shift?
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline keyboardlover
« Reply #12 on: Mon, 25 October 2010, 08:05:06 »
Sql server 2008 mgmt studio auto formats your queries. It's a huge time saver =)
I'm so glad we upgraded.
Offline ch_123
« Reply #13 on: Mon, 25 October 2010, 08:29:10 »
Is SQL case sensitive?
I should know this, I have a test on it in about 2 days.
« Reply #14 on: Mon, 25 October 2010, 08:30:44 »
Quote from: ch_123;238355
Your server's configuration dictates whether or not you can write case-insensitive queries.
Offline itlnstln
« Reply #15 on: Mon, 25 October 2010, 09:28:14 »
The code itself is not case-sensitive, but depending on the configuration, conditions on text can be.  I'm old school, I like all-caps.
Offline ichirichi
« Reply #16 on: Mon, 25 October 2010, 09:34:31 »
I have never tried this software, but it looks quite good for indicating a key status!
You can add your ownkey :
http://download.cnet.com/Clever-Keyboard-Indicator/3000-18493_4-10775290.html
Offline JohnElliott
« Reply #17 on: Mon, 25 October 2010, 14:35:47 »
Table names may or may not be, depending on the server. MSSQL lets you configure it either way.
Offline phate408
« Reply #18 on: Mon, 25 October 2010, 22:16:41 »
Quote from: keyboardlover;238344
Ech, SQL Server makes me a sad admin. But being a Unix admin I generally don't like most MS server products :P
-Das Keyboard Model S Professional Silent
-IBM Model M 82G2383 (Lexmark 1996)
-Compaq MX 11800
Offline Eclairz
« Reply #19 on: Tue, 26 October 2010, 03:47:25 »
I use shift+insert and shift+delete instead of control+x and control+v, just feels more natural on a standard keyboard, than creating a claw with my hand, i'm sure it made more sense when control key was placed in the caps-lock position. So placing a light on the insert key would make that key-combo redundant.
I rarely use insert for much else though, I also hate that it can overwrite, but after reading maybe i'll try using it within my coding practice.
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
« Reply #20 on: Tue, 26 October 2010, 06:55:57 »
Quote from: phate408;238736
ditto.
Offline itlnstln
« Reply #21 on: Tue, 26 October 2010, 07:00:47 »
I like SQL Server, personally, but only as a smaller system.  T-SQL is easy to write, and SQL Server gives you plenty of easy-to-use tools to get fairly complicated tasks done.  I love Teradata, though, since it pretty much uses straight, ANSI syntax and scales wonderfully.  Oracle is for sadists.  Writing complex UPDATE statements in Oracle makes me want to murder myself.
« Reply #22 on: Tue, 26 October 2010, 07:09:34 »
Quote from: itlnstln;238812
T-SQL IS easy to write, that's why I use SYBASE :P (actually, if I had my choice, I wouldnt use that either).
Long live postgres!
Offline itlnstln
« Reply #23 on: Tue, 26 October 2010, 07:11:47 »
Oh yeah, DB2 can eat a ****, too.  If a current date function is any more than one or two words, you're doing it wrong.
