Advanced search
typing on a cloud of . . .
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Marketplace
Interest Checks
(Moderator:
Signature
【IC】Fox65 mechanical keyboard kit-3 mode VIA/QMK 2 versions
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 【IC】Fox65 mechanical keyboard kit-3 mode VIA/QMK 2 versions (Read 4779 times)
chosfox
Thread Starter
on:
Mon, 03 June 2024, 22:38:32 »
Chosfox FOX65
Designed by Chosfox and Masro
From
Chosfox.com
SPECIFICATIONS
Layout: 65% keyboard 64/67 keys
Keyboard material: aluminum alloy shell (pure CNC)
Keyboard Structure: Gasket/Top Dual-structure
Dimensions: 322*114mm
Typing angle: 10°
Front height: 24mm
Back height: 34mm
Support: QMK/VIA (Windows / macOS / ios / Android)
QMK/VIA Supported for all 3 connection modes
2.4G Wireless/Wired/BT 5.1 Connection
1.2mm PCB, hot-swap supported
South-facing RGB
Shell process: electrophoresis / anodized
Interchangeable right-side Pusher/Keypad
PC plate: FR4, Pom
Counterweight: stainless steel, brass, red copper
Pusher/Keypad Version
PROTOTYPE
Standard Kit Includes:
CNC-machined aluminum case
Rotary encoder
Gasket Kit
Poron case foam/switch pad
Non-flex cut PCB
Flex-cut PC Plate
Logged
Bacms
Re: 【IC】Fox65 mechanical keyboard kit-3 mode VIA/QMK 2 versions
Reply #1 on:
Tue, 04 June 2024, 02:58:19 »
ISO support?
Logged
chosfox
Thread Starter
Reply #2 on:
Tue, 04 June 2024, 04:03:19 »
Logged
B4zookaw
Reply #3 on:
Tue, 04 June 2024, 06:25:08 »
ISO support, not iOS....
Logged
Print
Pages: [
1
Go Up
« previous
next »
geekhack
Interest Checks
(Moderator:
Signature
