Author Topic: [IC] KAT Iridescent ✨ - update: available in KAM at yuzukeycaps! & new deskmats  (Read 42147 times)
Offline minicap
UPDATE: now available in KAM at yuzukeycaps - see details here
KAT Iridescent
IC Form
https://forms.gle/nXmUXBf2Rn3bMjAG6
Website
https://katiridescent.com
About
This set was inspired by the colours of my radiant acrylic Arisu:
It’s hard to believe one piece of plastic can give off so many different colours! Iridescence also appears gorgeously in nature (gems, shells, butterflies…) and sometimes also in our everyday lives (soap bubbles!).
I aimed to capture this feeling in the gradient top row of the set as well as the multi-colour novelties. A lowercase serif font was chosen to give the set an elegant yet slightly whimsical look.
Manufacturer: Keyreative
Profile: KAT, 4-4-3-2-1-1 sculpt (like KAT Napoleonic / other sculpted profiles)
KAT usually uses a 5-4-3-2-1-1 sculpt, but I chose to use a 4-4-3-2-1-1 sculpt so that the base kit accent row can be used flexibly between the function row and numrow.
Material: Dye-sublimated PBT
Dye-sublimation was chosen over doubleshot KAT for more affordable pricing, given the all-custom legends.
Gradient top row
I adore accent numrows (e.g. Red Alert; my previous set KAM Sewing Tin also had one!), and thought it’d be an interesting way to showcase a gradient. I started with the accent numrow for 60-65% keyboards, and decided it’s more appealing for the accent to be on the function row instead for larger boards. This also makes the accent row optional for smaller boards.
To allow more flexible use of the accent keys, they are all novelties. ✨
Smaller boards (<=65%) have one complete run of the gradient from blue to yellow; for larger boards or boards with numpads, the gradient wraps around. Here’s a graphic to show how the accent row works on different kinds of boards:
Why not a uniform profile?
A uniform profile (e.g. KAM) would make the gradient top row more flexible! It would make the biggest difference in the 40s/Ortho kit. However, I personally wanted to make this a KAT set as I’ve already designed a KAM set in the past… and yes, I’m aware the profile for KAM Sewing Tin might’ve made more sense swapped too, but it’s too late for that 😅. There is a question in the IC about KAT vs KAM - I’ll consider switching the profile if KAM would be significantly more popular.
Photos of samples
With so many colours in the set, I requested a full set of samples for the IC to give a more accurate representation of how the set will look, rather than relying on renders.
These colours are approved and will be used in the production of the set. However, please note that there may still be slight visual differences in what you see depending on your browser, display and lighting.
Photos of the sample keycaps in studio lighting & on the CKC Discipline in studio lighting are by dakfu. Photos can be viewed in an imgur album here.
Sample keycaps in studio lighting: these are the most accurate colour reference.
On a CKC Discipline in studio lighting
On a CKC Discipline in indirect sunlight
On a Promise TKL in indirect sunlight
On my radiant acrylic Arisu in indirect sunlight
Kits
I've intentionally kept the number of kits small as:
1/ I’d like to run this as an in-stock set
2/ Keyreative now adds a percentage surcharge (sorting fee) for every additional kit beyond the 3rd i.e. more kits is now more expensive. (source: MOQ calculation spreadsheet in their discord server). This set is already going to have additional colour surcharges and I’d like to make it as affordable as possible.
So, it has “all in one” kitting like older Keyreative sets like KAM Wraith, Kitty KAT, etc. That being said, I’m very open to kitting feedback and suggestions - please feel free to let me know your thoughts in the thread or in the IC form. I will consider doing more traditional KAT kitting if I really can’t run this in-stock.
You can view all kits as an imgur album here.
Base
Supports TKL, 75%, 65% and 60% layouts. Add Numpad kit to support 100% and 1800.
For 100%, TKL and 75%, the accent row must be used on the function row.
For 65% and 60%, the accent row can either be omitted, or used as the number row.
40s/Ortho
Supports common 40% layouts including Minivan (12.75u), JD40 (12u), JD45 (13u), Dimple/UT47.2 (12.5u), prime_e (13u Alice), Bolt (12.75u Alice). Has physical support for QAZ with a 5 colour gradient rather than 6, since that looks more balanced.
Supports ortho including Preonic, Planck and ortho splits including Lily58, Iris, Corne
Supports 40s boards with partial numrow like V4N
With numpad, supports Milk Truck, Garbage Truck. Candybar supported with split backspace only (no 2u backspace, ask in IC if you want it added)
Two versions of the accent row are included: R3 for 40s boards (replaces qwerty row) and R4 for 5-row Ortho boards (replaces numrow). The accent is optional for 40s but must be used for 5-row Ortho boards as a cost compromise (as kit does not include regular numrow).
I originally planned omitting the R4 keys also for cost, meaning 3-3-2-1-1 profile instead of 4-3-2-1-1 profile for those ortho boards, but in the end decided to include them for the 5-row ortho users.
Ergo
Supports Ergodox, Boardwalk and Sol.
I wanted to be able to use the set on my own Ergodox, and think the top row gradient works well split across the two halves! To keep the kit more affordable, the gradient must be used on the top row (no regular numrow is provided), and there are many novelties to give more flexibility with legends. Text mods were chosen based on frequency of use in NoPunIn10Did’s KAT ergo kitting guide.
Numpad
Combine with Base Kit for 100% and 1800: 1800 users have the choice of using the R4 gradient as the numrow or not.
Combine with 40s/Ortho for Candybar, Milk Truck and Garbage Truck. R3 gradient can be optionally used as qwerty row.
Tailor
The interactive configurator from KAM Sewing Tin returns, with new boards and a new feature, changing the case colour!
You can try it out here: https://katiridescent.com/#tailor
Here's a GIF preview of the functionality:
Deskmats
updated may 2026 - new designs!
"clouds" (v2) is inspired by iridescent clouds
"border" is a more minimalist design featuring my favourite novelty motifs from the set
"gradient border" is for those who like the design, but want a more colourful deskmat
Similar to the keycaps, I hope to get samples of the deskmats made ahead of sales/production for a more accurate preview of the colours, etc - above are not final, just a preview!
Next up
- Deskmat designs
- Finding collabs
- Finding vendors
Credits
- Keyreative for the lovely samples and fantastic partnership
- dakfu for the gorgeous photography
- NoPunIn10Did for the KAT ergo kitting guide
- Devin Elle Kurtz for the fantastic cloud painting tutorial & brushset
- Everyone who supported KAM Sewing Tin, for giving me the energy to make another set 😊
Contact
Email: hi@katiridescent.com
Discord: minicat.
Instagram: @minicap.cat
Updates will be regularly posted to this thread as well as to my Discord server.
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=123097.0][img width=280 height=120]https://i.imgur.com/hLY7uab.png[/img][/url]
You can update your signature here - I appreciate the support!
IC Form
Thanks for reading this far! If you’re interested in the set or have any feedback, please fill out the IC form - I’ll be reading every response 💙
« Last Edit: Mon, 04 May 2026, 01:36:41 by minicap »
Offline minicap
Re: [IC] KAT Iridescent ✨
« Reply #1 on: Wed, 05 June 2024, 17:04:17 »
Update log
2026-05-04: New deskmat designs
2026-04-24: Live on yuzukeycaps.com!
2024-11-17: Deskmat designs
2024-06-24: 40s/Ortho kit updated: added 2u r3 backspace (gradient and non gradient versions) and changed 1.75u r1 lock to a novelty
« Last Edit: Sun, 03 May 2026, 21:47:01 by minicap »
Offline PhoenixUNI
« Reply #2 on: Wed, 05 June 2024, 17:58:21 »
Will you consider additional homing keys to cover Colemak or Dvorak users?
Offline minicap
« Reply #3 on: Wed, 05 June 2024, 18:20:49 »
Thanks for the question! Someone asked similar in my Discord just now - not sure if you're the same person, but I'll copy my response here so folks on GeekHack can see it too :D
This is currently not planned, though depends on what feedback I get in the IC
Since it's a sculpted profile, full Colevrak support would also require alternate alphas on top of the additional homing keys (included KAT Refined's Colevrak kit below as an example) and I chose not to include this in the initial kitting since in KAM Sewing Tin's GB only 11 Colevrak kits were purchased compared to 385 base kits / alphas - and that one was cheaper since it was a uniform profile. Similar reason for not supporting NorDe which only sold 6 kits in Sewing Tin's GB
With Keyreative's new pricing, each additional kit beyond 3 now makes the whole set more expensive - between that and wanting it to be in-stock I did make some tradeoffs to keep the kitting lean. But again, I do plan on seeing what feedback I get in the IC and making changes accordingly ^^
Offline keebibi
    • My Discord Server
« Reply #4 on: Wed, 05 June 2024, 19:01:43 »
So pretty! GLWIC!
Offline DerBonk
  • I'm just this guy, you know.
« Reply #5 on: Thu, 06 June 2024, 02:15:42 »
This looks amazing and the kitting sounds very well thought out.
Offline LMNPI
  • QAZ is love.
« Reply #6 on: Thu, 06 June 2024, 06:04:25 »
In love with the colorful Qwerty row as a 40s user this is so great to see!
+1 for Colevrak support
Offline TyPo.mk
« Reply #7 on: Thu, 06 June 2024, 10:21:02 »
This is a very nice interest check
Offline minicap
« Reply #8 on: Fri, 07 June 2024, 16:08:42 »
So pretty! GLWIC!
Thank you for the kind words!! 💖
Yes, wanted to make sure small boards would get to have the gradient too :D Noted on the +1!
Offline nebulazy
  • i heart keyborb
« Reply #9 on: Tue, 11 June 2024, 12:40:15 »
i love the accent row! ive been wanting to test KAT so this will be a great intro for me. i think this is super cute and i appreciate the alice support. i have a monka alice67 and it has huge bezels so it looks great with cute keycaps and i'd love to put this set on it
Offline minicap
« Reply #10 on: Sun, 16 June 2024, 15:22:37 »
Thank you for the kind comment!! I personally find KAT really comfy to type on :D I hadn't seen the monka alice67 before but just looked it up and those rounded edges are cute, hopefully will get to see Iridescent on it one day :D
Offline minicap
Re: [IC] KAT Iridescent ✨ - update: initial kitting tweaks
« Reply #11 on: Mon, 24 June 2024, 21:15:23 »
Thank you everyone for the comments, IC responses, etc so far! It's been a couple of weeks since the IC launched, I've been reading every single response & comment and really appreciate the kind words and enthusiasm 💙 I've made a few small kitting changes, and have several other things I'm monitoring but want to collect more IC feedback about first before actioning as they are larger changes.
Wanted to share my detailed thoughts for those who are interested but will put a tldr/summary first:
Summary
* 40s/Ortho kit has been updated: added 2u r3 backspace (gradient and non gradient versions) and changed 1.75u r1 lock to a novelty
* Revisiting idea of novelty/gradient spacebars & looking into base kit capslock novelty (either text novelty or image novelty)
* Will be continuing to collect IC feedback to inform larger changes - may make more kitting updates in the future
* Set is staying as KAT
* Deskmat design up next
* Artisan collabs will come when set is further along (hesitant to reach out to makers this early)
General feedback
* 4 requests for different font/capitalised alphas: The lowercase serif font and the gradient top row are the two main features of the design in my mind so I'm not planning on changing those, though I understand the quirkiness will be a draw for some and a dealbreaker for others. The set does use Keyreative's stock white, so it's theoretically mix-and-match-able with other KAT sets like KAT Alpha (which has blanks): https://divinikey.com/products/kat-alpha-keycap-set-dye-sub-pbt
* 3 requests for Colevrak support: this isn't enough for me to justify adding a new kit for it yet (as each additional kit makes the whole set more expensive) but I'll continue monitoring IC feedback about this. Similar for the 1 request about iso fr support and 1 request for night version
* 3 requests for more colour: I previously looked into gradient spacebars but personally found it too distracting & preferred having the top row gradient as the main focus. I'll be picking this back up to see if I can find something I'm happy with
* 2 requests to have alpha legend gradient in 40s/ortho: will not be happening as it would require additional keys to be added (as depending on the board, some keys could be different colours e.g. on a minivan, W would be purple, but on a QAZ it'd be blue)
* 1 request for icon mods: I actually did originally want to do full, custom icon modifiers that matched the font/theme but I wasn't able to design a set I was happy with, hence the text mods instead 😔
Specific kitting requests
For these, I'm balancing making sure the kits work to cover as many boards as possible while also trying to keep the cost of the set affordable. As such, I'm prioritising adding keys that add net new support over keys that already have alternatives (i.e. physical support already exists), and also prioritising keys that are more flexible (e.g. a novelty over specific legends)
Here are the minor changes I've already made based on feedback, both in the 40s/ortho kit:
* change 1.75u r1 Lock to the iris novelty; this allows it to be used more flexibly (e.g. as a second shift on boards with 2 x 1.75u Shift). This is the same novelty as 1.75u r2 Enter, AFAICT there aren't boards where you'd have to use both together, but I made it face the other way for variety anyway
* Added 2u r3 Back for Candybar
Here's a summary of the other feedback and how I'm thinking about it:
Base kit
* 1 request for r2 1.75u fn - base kit currently has caps and ctrl. I'll be considering replacing these with a text novelty or image novelty if I can think of something that works well
* 1 request for Mac legends (cmd/opt) - punting for now as novelties can be used instead of ctrl, and "shine" is already OS neutral
40s/Ortho
* 2 requests for ISO enter - punting for now due to cost; there are two iso enters in the base kit, so i think it'd be possible to get the ISO keys affordably aftermarket from someone who bought the base kit that doesn't need them
* 2 requests for more novelties - 1.75u r1 has been added
* 1 request for QAZ legend support (currently only has physical support) - punting again for cost concerns
* 1 request for 2u backspace for candybar - done
* 1 request for second 1.75u shift; 1 request for 1.75u r1 novelty for full novelty mods - done (changed 1.75u lock to novelty)
* 1 request for double 3u spacebars - punting for now as i revisit gradient/novelty spacebars. if i end up adding a separate spacebars kit itll go in there instead
Profile: will stay as KAT
46.8% of responses were neutral, 30.6% preferred KAT and 22.6% preferred KAM - this is enough for me to rule out switching to KAM, the question has been removed from the IC.
Accessories/collabs
Artisan collabs and Deskmat were the most requested by far! I want to do both of these, but also want to wait until the set is further along and has more certainty before reaching out for artisan collabs. So, I'll be working on deskmat designs next ^^
Offline minicap
« Reply #12 on: Sun, 17 November 2024, 18:12:37 »
Hello, it’s been a while! Presenting the deskmat designs for KAT Iridescent - “clouds” and “border”! I’ve been working on them slowly but surely over the last several months and am excited to share them :D
"clouds" is inspired by iridescent clouds - also featuring some fluffy cumulus clouds! "border" is a more minimalist design featuring my favourite novelty motifs from the set. I personally prefer simpler deskmat designs (I find them too distracting otherwise!) but also wanted to have a option that really showcases the colours of the set ✨
Doing the cloud illustration was a stretch for me - I spent a while practicing drawing clouds before getting started 😅 and quickly realised I would not be able to do realistic clouds - so we have some very stylised clouds instead that I hope capture a little of the wonder of iridescent clouds in nature ☁️ Also shout out to Devin Elle Kurtz's fantastic cloud painting tutorials and brush pack - highly recommend - though I ended up with a more cel-shading-esque style for the deskmat
I also made an illustration to show what the deskmats might look like as part of your setup and with a keyboard wearing KAT Iridescent on top ✨
Similar to the keycaps, I hope to get samples made of the deskmat designs before sales occur so that folks can get the most accurate preview possible of what it’ll look like. So, the colours you see above are not final!
Up next: I’ve been reading each IC response as they come in (thank you for all of the comments and feedback!) but will be going back and collating the feedback again for another potential round of kitting tweaks. And starting to reach out to vendors 🤞
Offline DerBonk
Re: [IC] KAT Iridescent ✨ - update: deskmat designs!
« Reply #13 on: Wed, 27 November 2024, 02:59:50 »
Lovely work! I really like the borders mat design. Looks simple, yet cute and sparkly. I just don't know if I should usea mostly white deskmat. But that's a me and my spills problem lol
Offline minicap
« Reply #14 on: Fri, 24 April 2026, 01:41:17 »
Hey all! Excited to announce that KAM Iridescent is now available as a yuzukeycaps.com creation!
You can view it here (note: links include my affiliate code, which increases the share I get from Yuzu on any sets purchased)
For those unfamiliar with Yuzu, they partner with Keyreative to produce keycaps on-demand. Via their online configurator, you can customise and order exactly the keys you want - any keyboard / language / layout. Each keycap's colour and legends can be customised. They also partner with designers for "Creations", where you can start from an already designed set instead of from scratch (and designers get a design fee).
First, here are some photos of the final product / R2 Yuzu samples in indirect sunlight (imgur album with more photos here) - there are also nicer photos by the pro photographer Yuzu works with on the Yuzu website
Boards: CKC Discipline, Minivan, Promise87, LAZYDESIGNERS Bolt
Why Yuzu?
Part of the reason why this set was paused for so long was due to the current state of the keyboard market - given the niche appeal of the set, I was worried about whether a GB could succeed. (Another part was due to some RL stuff for me - I really appreciate everyone's patience!)
Yuzu's on-demand model means avoiding the uncertainty and MOQ of a GB, plus gets the set to people's hands faster compared to a GB (Yuzu usually processes orders within 1-2 weeks). I also really like how with Yuzu folks can customize the set to be exactly the keys they want and need - vs in a GB, less popular items like international support, having legends on your gradient, etc would not have enough demand to make separate kits for.
e.g. if you're a 60-65% user, you could get your numrow in gradient colours but with legends; if you're a 40%s user you can get gradient qwerty legends. And this is possible for colemak/dvorak/any language, not just querty english :D
The Yuzu team have also been great to work with throughout this process!
Changes vs IC
Some changes from the original IC were necessary:
* KAM instead of KAT: Yuzu does not support KAT and it isn't on the immediate roadmap. The original IC had a lot of interest in KAM too, so I felt this would be acceptable.
* Different colours: The set uses Yuzu's set colours instead of custom Pantones. I picked the closest ones based on Yuzu colour samples, but there are still differences:
    * Yuzu's stock white is different
    * The yuzu colours overall are a bit more muted/darker - the gradient becomes more pastel-like than rainbow-like
    * The purple became more blue-ish while the pink became more purple-ish
* Cost: Cost for a full kit (e.g. base kit) is higher compared to usual GB pricing, due to the on-demand aspect, but it is comparable/cheaper if you only order the keys you need for a specific keyboard (e.g. a standard 65% is ~$64, a standard TKL is ~$81)
Here are some photos of the R1 Yuzu samples with the original KAT samples for reference (after getting these, I ordered R2 samples with smaller legends and different blue on the alphas/mods, which is what the final set uses)
Overall I'm happy with these compromises and feel my original vision for the set is still being achieved.
How to order on Yuzu
To make customisation a bit easier (specifically, adding multi-colour novelties is a bit difficult), i've made KAM versions of the IC kits (base, 40s/ortho, ergo, numpad) & examples of gradient numrow and qwerty row with legends. you can either get started by picking a specific keyboard, or by copying one of those kits and deleting all the keys you don't want (would strongly recommend deleting to reduce cost / avoid getting keys you don't need!)
To get started, go to the creation page, from there you can click "Create my keycaps" and choose a specific keyboard from the Yuzu playground, or open the URL to one of the premade kits & "Copy" and edit.
I've also made a Notion guide that explains how to configure things in Yuzu: feel free to also ask questions here or in my Discord server, happy to help!
Phew! Thanks for reading :D and if you supported this set anywhere along the way, a sincere thank you for your support and patience! Would love to see any photos of the set on your keyboards, please feel free to share here, tag me on ig (@minicap.cat) etc :D
here's the link to the yuzu creation again!
Offline minicap
with the keycaps now available (tysm to those who have ordered btw!! hope they get to you safe and soon) i've been revisiting the deskmat designs. i plan to have 3 available:
1. "border" (from original IC)
2. 🆕 "gradient border"
3. 🆕  "clouds v2"
here are the new designs + the illust mockups with them as part of a desk setup 😄
in the original "clouds" deskmat from the IC (inspired by iridescent clouds), there was a gap i couldn't close between my vision and what i actually was able to draw/paint  😭 so, i had another go at it! the new version isn't perfect either, but im much happier with it! snuck in a butterfly to represent the set as well as a cloud version of my mascot cat, Print 🐈
if you liked the strong gradient from the original clouds design, no worries - i've also added a new "gradient" version of the "border" deskmat from the original ic. there was feedback that folks liked the design but didn't want a white deskmat, so here's a more colourful version!
next ill be looking for vendors for the deskmats! ive also done some reachout for artisan collabs 🤞
