Author Topic: LK401: Some keys have died.  (Read 3951 times)
Offline Professor Fate
« on: Fri, 07 June 2024, 16:47:28 »
Hi folks,
I've run into a serious problem with the LK401 of my VT420: Some keys in the left upper corner (F1 thru F5, caret, number '1') lo longer emit any keystrokes after not having been used for a couple of years. As some of you may know, F3 gives access to the set-up menu of the terminal. I've opened the case of the keyboard and removed the keycaps in question, but can't find anything strange, not even on the PCB:
See https://photos.app.goo.gl/NJFCjiokFc5zxukR6 for images in full resolution.
Now: How can I bring these keys back to life? In know the LK401 is a rubberdome board with conductive strips printed on plastic sheets, and I've already run into a similar issue with a Model M (which turnd out to be lethal), I really wanna scrap another keyboard. Any hints?
Re: LK401: Some keys have died.
« Reply #1 on: Sun, 16 June 2024, 11:25:06 »
OK, I disassembled the board and found out that some of the conductive strips on the lower of the two plastic sheets are corroded:
So I applied some conductive varnish to the strips, reassembled and connected the board…and suddenly found out that the keys do work, but emit the wrong keycodes:
F1 → s
F2 → e
F3 → w
1 → a
What's wrong here? :mad: Did I apply too much varnish, or did it flow over an adjacent strip when reassembling the keyboard?
