Author Topic: Heavy keyboards appreciation thread - Post your heaviest keyboards!  (Read 8300 times)
Offline kbd0
I'm sure I'm not alone in appreciating particularly heavy keyboards.
What are the heaviest keyboards you have or know of? Post them!
« Last Edit: Wed, 12 June 2024, 20:28:46 by kbd0 »
Offline kbd0
Re: Heavy keyboards thread - Post your heaviest keyboards!
« Reply #1 on: Wed, 12 June 2024, 19:57:40 »
Mine is this Viatrion keyboard from 1969 weighing in at 21lbs (9.5kg)
Inside the steel shell is a giant metal block containing the light channels it uses for sensing
Offline splodeybaloney
Re: Heavy keyboards appreciation thread - Post your heaviest keyboards!
« Reply #2 on: Thu, 13 June 2024, 14:09:50 »
Not quite on the same level as yours but here's mine, this weighed in around 10 lbs 9 oz (4.8kg) at a meetup and won me an award for the heaviest board there that day. Most of the case is 7075 aluminum but the bottom half has a big brass weight, and the plate is brass as well.
Offline clay
  • No foams
« Reply #3 on: Thu, 13 June 2024, 22:41:47 »
Realforce R3S with Sho Labs S108 custom aluminum case. 3.9 kg / 8.6 lbs
Offline clay
  • No foams
« Reply #4 on: Thu, 13 June 2024, 22:42:51 »
Offline Tseg
« Reply #5 on: Mon, 17 June 2024, 08:55:02 »
I have to admit, I am a fan of heavy boards... I even added tire balancing weights inside my Neo65 to bump up the weight.  I believe my 9lb F77 is the heaviest, but I have a copper-bottomed Smith + Rune 165 CE showing up by the end of the year that may give it a run for the money, especially when paired with the matching copper-bottomed key pad.   I suppose there is something special about a board that is naturally heavy vs. screwing on weights to make it feel heavy.
Offline longcao1010
« Reply #6 on: Tue, 02 July 2024, 21:52:40 »
What is the name of this kb / case? Thank you!
Offline xjack312
« Reply #7 on: Tue, 02 July 2024, 22:42:39 »
~7.5lb custom southpaw alice layout I designed last year, big brass weight on the back
308761-0
308763-1
Alice enjoyer
Offline kajahtaa
« Reply #8 on: Wed, 03 July 2024, 00:18:56 »
Heh
About 7 kg
« Reply #9 on: Wed, 03 July 2024, 13:03:12 »
It is just called the "Southpaw Fullsize" from Switchplate Peripherals. I actually have another one that I'm trying to sell, feel free to send me a message if you are interested
