Author Topic: [IC] GMK TELEX/Viet Add-on Kit  (Read 9262 times)
Offline khai
  • Formerly spoonr00t
« on: Fri, 14 June 2024, 00:05:26 »
GMK TELEX/Việt Add-on
A simple add-on kit, to be used with a beige set for Vietnamese support.
IC Form (Intl./English)
IC Form (Tiếng Việt)
Hello / xin chào
I wanted to run this set because I haven't seen a good Vietnamese set yet, and I don't think there was a nice add-on kit before despite how big the Vietnamese MK community is.
Kitting
Colors
This will be using stock GMK colors, L9 base and CR legends
This will also be doubleshot, besides the tulip-esque key and the two characters with front facing print
Vendors and Pricing
TBD, just looking for interest and feedback for now
Other notes
- Not planning for this to become a full base kit because we have enough beige and WOB floating around.
- Tulip-esque key, and bracket keys with front facing legends will be UV printed.
- I know it's missing a scooped F and J key. Will correct it as soon as I can.
- Bottom row key novelties are NOT finalized, but they will be of a lotus and will be pink!
Credits
- masje, for helping me out and providing the wonderful render you see here
- mamahuhu, for helping me with the kitting
- Hastura, for helping me translate the IC forms
- nuoc thockers, you know who you are
- marshmellohs, for inspo on the novelties
- Druah, for being Druah.
« Last Edit: Mon, 23 September 2024, 14:27:38 by khai »
Offline DirtyGingy
Re: [IC] GMK TELEX/Viet Add-on Kit
« Reply #1 on: Fri, 14 June 2024, 00:47:17 »
I might not be the person for this set, but I really hope this goes well. Good luck!
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Fri, 14 June 2024, 00:52:27 »
Definitely interested and likely only in GMK. Would be great if novelties could be considered in R5 as well considering how many sets there are now with it (9009 R3, Classic Beige, KA1953, Hineybeige, etc)
Offline lampmk
  • wk 60 > wkl
« Reply #3 on: Fri, 14 June 2024, 01:11:33 »
my vietnamese is terrible but i still want it. cảm ơn em khai :p
« Last Edit: Fri, 14 June 2024, 01:13:15 by lampmk »
My collection -
Ovinnik - Kaze - Dodici - Spyder - Duck Eagle v3 - TGR Dolice - HHKB Pro2 Type S - Heavy Grail GOCF - Matrix Falcon
Offline vinnyy
« Reply #4 on: Fri, 14 June 2024, 01:13:31 »
This is so good man, love this, you have my full support! :thumb: Cam on!!
collection:
   Daji Ocho Cuatro x3, Daji Ocho Cuatro 2XL, HHKB Pro 2, Filco 1
Offline Choerry
  • stan loona
« Reply #5 on: Fri, 14 June 2024, 01:14:28 »
need this in my life, i'll take 3
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #6 on: Fri, 14 June 2024, 01:33:44 »
Cool little project, said this in the IC but would be down for a wob one if you decide to do it.
GLWIC
also not the person for this set, but more cool addon kits that cater to groups the better.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Bunn3y
« Reply #7 on: Fri, 14 June 2024, 04:23:37 »
+1 to this. Beige needs r5 support. GLWIC!  :thumb:
Collection: Ivery Praxis || HHKB Pro 2 || JTD.Works Ovinnik || Realforce R1 87u || Switchplate iiA Sanction
Offline DirtyGingy
« Reply #8 on: Fri, 14 June 2024, 06:11:10 »
GLWIC
Exactly what I was thinking. More layouts and language support is good. Also, if someone were to design a set with Viet as an intentional choice because of those, I think that would be lovely
Offline headless
  • Founder tại The Keebs of Leser
    • The Keebs Of Leser
« Reply #9 on: Fri, 14 June 2024, 12:30:10 »
This is very cool, man !
Dự án này cool quá sếp ơi  :thumb:
Offline marshmellohs
« Reply #10 on: Fri, 14 June 2024, 15:30:15 »
need
Offline IOVERCALLHISTIOCYTES
« Reply #11 on: Fri, 14 June 2024, 16:59:14 »
I’m pretty white but I’d buy because of the novs
Offline Meepergon
« Reply #12 on: Fri, 14 June 2024, 19:58:56 »
while I'm not the target audience for this set (like others have also commented), i absolutely love that this exists and wholeheartedly support this and other future sets like this!!
Offline sauvieng
« Reply #13 on: Fri, 14 June 2024, 20:57:30 »
love it, though i definitely want to see a WOB version of this.
Offline Horu
« Reply #14 on: Sat, 15 June 2024, 00:44:51 »
VNI user need to get some love too.  ;D
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #15 on: Sat, 15 June 2024, 10:14:46 »
Can't speak or type Vietnamese, but I see a Tulipesqe key & that means I must buy! Seriously though awesome work as you are correct I don't think there ever has been a GMK set featuring keys for Vietnamese, GL with IC!
« Reply #16 on: Sat, 15 June 2024, 10:56:04 »
Now that I looked at this closer,
The novs are 1u and 1.25u, and given people’s preferences, either adding 1.5u or switching 1.25u to 1.5u might make more sense.
I’d get two sets and then see if I can’t track down Bear from prime 2020 MGB to give alphas
Offline Rob27shred
« Reply #17 on: Sun, 16 June 2024, 04:09:19 »
Good eye, I had just assumed they were 1.5u & 1u keys. OP I second this, adding 2 - 1.5u modifiers would definitely help push this through to reality.
Offline Hastura
« Reply #18 on: Mon, 17 June 2024, 06:00:20 »
hell yeah :p
Collection:
daji seis cero | HHKB Pro 2 | Ninja Majestouch 2
Offline Piperaceae
  • Formerly filefish
« Reply #19 on: Mon, 17 June 2024, 06:12:58 »
I know the novelty key isn't finalized, but right now it looks like it's two different shades of pink? If it were just one, it could be doubleshot; as it is, it'd need to be UV printed.
Offline mr_foggy
  • neue = nope
« Reply #20 on: Fri, 21 June 2024, 11:36:22 »
filled the IC. I want this.
Offline Choerry
  • stan loona
« Reply #21 on: Wed, 16 October 2024, 12:27:17 »
Has there been any progress regarding securing vendors for this? I dream about this add-on kit every night.  :D
