Author Topic: Not new but back  (Read 4154 times)
Offline AmigaDisk
  • Formerly ohm-ish
Not new but back
« on: Fri, 14 June 2024, 01:23:26 »
Hello again
I love keyboards  :D
Online Rhienfo
  • GOTHETIGES
Re: Not new but back
« Reply #1 on: Fri, 14 June 2024, 01:31:33 »
Welcome back to geekhack :)
Saw you on the other stuff you made and just thought to say hi here.
What boards do you have?
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #2 on: Fri, 14 June 2024, 02:08:57 »
Hi  :cool:
For a while I've been pretty happy with my Varmilo VEM88 V2 with EC Rose switches.
I'm looking at getting some custom keycaps. Not many to find for nordic ISO layout..
Online Rhienfo
  • GOTHETIGES
« Reply #3 on: Fri, 14 June 2024, 03:17:50 »
Hi  :cool:
nordic layouts are far more limiting in sets but there is still some sets out there. There aren't too many more budget oriented options that I could find.
The one that I would recommend personally is gmk norde, comes in a couple of colourways and should have the kitting, for a keyset it's expensive but the quality is extremely good (I have gmk on my mechanical keyboards and they are great)
You can get them here - https://oblotzky.industries/products/gmk-cyl-norde?variant=44609459781900
good luck with finding the caps you are looking for though, if this doesn't help  :)
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #4 on: Fri, 14 June 2024, 03:22:33 »
Thank you  :thumb:
