Author Topic: Amiga 500 keyboard  (Read 5104 times)
Offline AmigaDisk
  • Formerly ohm-ish
Amiga 500 keyboard
« on: Fri, 14 June 2024, 02:50:19 »
I had an Amiga 500 computer back in 1987-1993 ish (yes I'm that old)
Loved that machine. And the keyboard was pretty great
Does anyone know what kind of keycaps and switches the Amiga 500 had/has?
Or some other info
« Last Edit: Fri, 14 June 2024, 03:52:54 by ohm-ish »
Offline Rhienfo
  • GOTHETIGES
Re: Amiga 500 keyboard
« Reply #1 on: Fri, 14 June 2024, 03:10:51 »
From the deskthrority page about the amiga 500 they seemed to have hi tek "space invader" switches or Mitsumi hybrid switches.
From looking it seemed that early versions had the space invaders and the later, more common varients had the mitsumi switches.
Not too sure about those mitsumi switches but space invaders are pretty good.
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #2 on: Fri, 14 June 2024, 03:18:36 »
Thanks
Is that rubber domes?
I seem to recall the amiga 500 switches feel as rubber dome + still a bit mechanical. Not sure, long time ago ;)
« Last Edit: Fri, 14 June 2024, 03:20:08 by ohm-ish »
Offline Rhienfo
  • GOTHETIGES
« Reply #3 on: Fri, 14 June 2024, 03:30:56 »
Thanks
Space invader switches are fully mechanical, but from watching a review of the mitsumi hybrids they have a rubber "foot" attached to the switch slider and rubber pads on the slider as well, so yours was probably the mitsumi hybrids one. I'll link the review which includes the talk about the switches.
Offline Surefoot
« Reply #4 on: Fri, 14 June 2024, 14:16:36 »
I did have one of the Amiga 500 with Space Invader switches and indeed that keyboard was excellent, certainly gave me the taste for perfect linear switches.
Then I had the 1200 with the Mitsumi rubber domes and this was quite a letdown in comparison.
« Reply #5 on: Fri, 14 June 2024, 16:31:36 »
The Mitsumi "hybrid" switches in Amiga 500 keyboards where the ones with coiled metal springs under the keycaps for return force. The mushiness comes from the foot of conductive rubber at the bottom of each slider.
The separate keyboards for Amiga 2000, 3000 and 4000 were ones with rubber sleeves instead of springs.
« Last Edit: Fri, 14 June 2024, 16:33:43 by Findecanor »
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #6 on: Sun, 16 June 2024, 05:53:25 »
I don't remember the details. So long ago
Maybe it had the mitsumi hybrids, dunno.
I still loved the keyboard
