Author Topic: Amiga 500 keyboard  (Read 2246 times)
Offline AmigaDisk
  • Formerly ohm-ish
Amiga 500 keyboard
« on: Fri, 14 June 2024, 02:50:19 »
I had an Amiga 500 computer back in 1987-1993 ish (yes I'm that old)
Loved that machine. And the keyboard was pretty great
Does anyone know what kind of keycaps and switches the Amiga 500 had/has?
Or some other info
« Last Edit: Fri, 14 June 2024, 03:52:54 by ohm-ish »
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: Amiga 500 keyboard
« Reply #1 on: Fri, 14 June 2024, 03:10:51 »
From the deskthrority page about the amiga 500 they seemed to have hi tek "space invader" switches or Mitsumi hybrid switches.
From looking it seemed that early versions had the space invaders and the later, more common varients had the mitsumi switches.
Not too sure about those mitsumi switches but space invaders are pretty good.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #2 on: Fri, 14 June 2024, 03:18:36 »
Thanks
Is that rubber domes?
I seem to recall the amiga 500 switches feel as rubber dome + still a bit mechanical. Not sure, long time ago ;)
« Last Edit: Fri, 14 June 2024, 03:20:08 by ohm-ish »
Offline Rhienfo
« Reply #3 on: Fri, 14 June 2024, 03:30:56 »
Thanks
Space invader switches are fully mechanical, but from watching a review of the mitsumi hybrids they have a rubber "foot" attached to the switch slider and rubber pads on the slider as well, so yours was probably the mitsumi hybrids one. I'll link the review which includes the talk about the switches.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline Surefoot
« Reply #4 on: Fri, 14 June 2024, 14:16:36 »
I did have one of the Amiga 500 with Space Invader switches and indeed that keyboard was excellent, certainly gave me the taste for perfect linear switches.
Then I had the 1200 with the Mitsumi rubber domes and this was quite a letdown in comparison.
« Reply #5 on: Fri, 14 June 2024, 16:31:36 »
The Mitsumi "hybrid" switches in Amiga 500 keyboards where the ones with coiled metal springs under the keycaps for return force. The mushiness comes from the foot of conductive rubber at the bottom of each slider.
The separate keyboards for Amiga 2000, 3000 and 4000 were ones with rubber sleeves instead of springs.
« Last Edit: Fri, 14 June 2024, 16:33:43 by Findecanor »
Offline AmigaDisk
  • Formerly ohm-ish
« Reply #6 on: Sun, 16 June 2024, 05:53:25 »
I don't remember the details. So long ago
Maybe it had the mitsumi hybrids, dunno.
I still loved the keyboard
