Author Topic: The thock unappreciation thread  (Read 3906 times)
Offline grids
« on: Wed, 19 June 2024, 04:12:20 »
Am I the only one who *really* dislikes the word "thock" (double dislikes if it comes with 2 c's!)?
"Thocky" keyboards themselves are fine; it's just the term itself that I'm talking about.
(No, but really.)
(Wanted to post this in "Keyboards". Oh well.)
« Last Edit: Wed, 19 June 2024, 04:14:13 by grids »
Offline Piperaceae
  • Formerly filefish
Re: The thock unappreciation thread
« Reply #1 on: Wed, 19 June 2024, 08:19:12 »
I'm mostly bothered by the fact it has no real meaning; it's just a word people assign to whatever their preferred sound is. No two people use it for the same sound. Anything that's not a an unpleasantly high-pitched noise is just automatically thock.
Offline winkwork
    • tunnel rush
« Reply #2 on: Wed, 19 June 2024, 22:12:35 »
Same here! I appreciate a good keyboard sound, but 'thock' makes me think of something hitting a wall. It's just not a pleasant word.
Offline TomahawkLabs
« Reply #3 on: Thu, 20 June 2024, 09:50:02 »
Thock is just the inverse of clacky. I would describe "thock" as the sound that has a heavily dampened case and well lubed and quality stabilizers. Keyboard sounds are all the sounds your keyboard makes at the same time combined. So when you reduce those higher pitched tones that are distracting (often from wobblily keys/stabilizers, echoes in the case, etc) you are left with thick plastic hitting solid surfaces.
Any amount of plastic squeaking as the case flexes will contribute to that higher sound. Higher pitches require less energy to produce the same level of sound pressure than lower sounds do, which is why subwoofer amplifiers are 5-20x the power rating as speaker amplifiers.
If you want that deeper (thock) sound you need a desk mat to absorb the force coming from the case into your desk as you type, a quality case that doesn't flex or creeeeeek as you type on it, and case/plate foams can very much deepen the sound.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #4 on: Fri, 21 June 2024, 05:12:23 »
I've never liked these terms, they always sounded weird to me. I just like describing sound by like how high or low pitched it is, how full or hollow it is, is it resonant or dead sounding etc. More accurate than "thock" or "clack" ever will be.
 Also very strange that how thock changed from describing what topre sounded like to generally deep sounding switches as well.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Evolurkeeb
« Reply #5 on: Tue, 25 June 2024, 03:05:20 »
Agreed, these terms are highly subjective.
Offline Hans_Luber
« Reply #6 on: Sat, 29 June 2024, 10:12:48 »
petition to change clack to thwack.
Offline Pyre
« Reply #7 on: Sat, 29 June 2024, 20:19:08 »
I think the terms give people a good general reference point to what something sounds like - but they are a sign of the hobby becoming more 'consumerist' where everything is boiled down to marketable buzzwords
I arbitrarily draw the line at 'creamy' - thats just weird :D
Offline Fraaaan
« Reply #8 on: Sun, 30 June 2024, 07:53:30 »
But it doesn't. Thock has been used to describe every trendy keyboard sound in the last 4 years.
Topre? Thock.
Deep sounding MX build? Thock.
Foam? Thock.
8 different foams? Thock.
Ceramic keycaps? Thock.
Offline grids
« Reply #9 on: Fri, 05 July 2024, 15:17:09 »
My interpretation is that "creamy" is the sound/feel you'd think you'd get if your keycaps were mounted on mayonnaise, or some other high-viscosity substance.
(If this is correct then it's equally as insane as "thocky".)
(With the "mod" videos I've watched, I'm surprised no one has made a "mayo mod" before.)
