Author Topic: need help with numeric macro keyboard  (Read 3510 times)
Offline zadorid88
« on: Thu, 20 June 2024, 09:02:23 »
So I want to build my own membrane numeric macro keyboard, but I don’t know the name what controls the circuit. What is that big black thing on it? How can I reprogram it? No QMK answers pls, that isn’t for this. Thanks!
Offline TomahawkLabs
Re: need help with numeric macro keyboard
« Reply #1 on: Thu, 20 June 2024, 09:21:49 »
That black dot of glue/epoxy is so you will never know what's underneath. Electronics manufactures do this to obscure their PCBs/Chips so they cannot be replicated easily. Whoever put that there didn't want you to know what was underneath. I would suggest grabbing a Pro Micro and using that as the brains for the numpad.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
Offline zadorid88
« Reply #2 on: Thu, 20 June 2024, 23:15:02 »
Thank you!
So that green thing is a pcb, with a microprocessor under that black cover? How do you program this? How do manufacturers do this?
« Reply #3 on: Fri, 21 June 2024, 08:10:52 »
Correct, the green board is the PCB and the microcontroller is underneath that black dot. You won't be able to program it without some deeper knowledge in circuits and Microcontroller coding. Realistically your best bet is going to be swapping out the current microcontroller for a product like a pro micro or similar Microcontroller (MCU) that already has good documentation and support.
You could try mapping the matrix like others have done here.. That linked thread will give you all the information (outside of a specific step by step) of what it takes to do what you are wanting to do. But my honest opinion, it's a membrane keyboard and not worth the investment and time. If you are curious about learning keyboard hardware and flashing custom macropads, etc. I would just buy this Adafruit Macropad.
It's based off the RP2040, which isn't the most popular microcontroller in the keyboard world, but is gaining traction. Adafruit also has TONS of educational articles and guides here. I am also trying to teach myself microcontroller design. It's a steep hill with very little in the way of introductory projects. Good luck.
SA: Camping
