Author Topic: Any keyboards where you type keys with finger joints rather than move your finge  (Read 4739 times)
Offline TheWonderAlmighty
Basically you would keep your fingers still and bend them straight while hovering over the keys, pressing keys with the top middle of bottom or tip of each finger. I haven't tried this out other than brief tests on my Macbook keyboard, it doesn't work well on staggered keyboards but might on ortholinear ones. Ideally, with enough practice it would feel fine to type lots of keys very fast and hopefully achieve a high WPM with less errors than regular touch typing as the result of reduced finger movement.
I did some looking up to see if such keyboards exist but didn't find anything other than the the Lynxware CAT https://www.lynxware.org/ (look at photos on the page). I also looked at the Azeron Cyborg which also uses minimal finger movements, though you have to insert your fingers in each slot.
Offline Sup
Corne split ortho 4x5 is your answer you only bend your fingers the rest is under layers and combos and other thousands of combos
current
Coming soon
Offline grids
The keypad on a mouse like the Logitech G600 is something you can press with your thumb joints.
