Author Topic: [GB] Rich75 - A 75% tri-mode with monitor keyboard | GB is live right now  (Read 16817 times)
Offline ThomasLT
    • ThomasLT Studio
Layout:75%
Base Price:$239.99+shipping
Units: Unlimited
GB date: From July 7th to August 8th
The group buy will be held at https://www.thomasltstudio.com/
Estimated fulfillment date: Q4 2024
JOIN OUR DISCORD FOR FREQUENT UPDATES: https://discord.gg/fjSn5dsFCj
Instagram: https://www.instagram.com/thomaslt_studio/
Base Kit Specifications
  • Sound pack
  • 6° typing incline, front height 20mm
  • Grade 6063 aluminium case
  • Stainless steel PVD
  • 1.2mm flex cut FR4 plate
  • 75% layout PCB and daughter board
  • 2.4G USB dongle
  • 6000mah battery (100hrs with all light and monitor on)(at least 3 month with no light and monitor off)
  • Leaf-spring mount accessories
  • Interchangeable Two-key slot and badge slot
  • Screwdriver
  • Light guide accessories
  • rubber feets
PCB Specifications
  • Triple Mode PCB(Wired/Bluetooth 5.0/2.4Ghz)
  • Center USB-C
  • 1.2mm thickness
  • Via or MMPanel driver supported
  • Hot-swap (support monitor, MMPanel driver only)
  • Solder (DOES NOT support monitor, VIA driver only)
Case Color
E-coating
  • White
  • Cream
  • Pink
  • Peach
  • Purple
Spray-coated
  • Pink
  • Purple
  • Milky Yellow
  • Green
  • Haze Blue
  • Blue
  • Red
  • Coffee
  • Black
Price for parts
OLED monitor:$30
Fanta Lab stab:$15
Extra Plates:
Aluminium (no flex cut):$30
POM (no flex cut):$35
polycarbonate (flex cut):$20
FR4 (flex cut):$20
OLED monitor kit:$30
Weight selection
Polished Silver: Free
Polished Gold:$10
Polished Multi-color:$30
Extra PCB
Hotswap: $45
Solderable: $40
Renders
Color combos
Protos
Hotswap layout
Soldering layout
Join us on Discord & Instagram:
Discord: https://discord.gg/fjSn5dsFCj
« Last Edit: Sun, 07 July 2024, 07:39:46 by ThomasLT »
Offline ThomasLT
    • ThomasLT Studio
Hey everyone, we will be streaming today at 9 PM EST. Check the Discord for the link and join us!
Offline ThomasLT
    • ThomasLT Studio
We are giving away two keyboard, check my instagram for more info !
Offline ThomasLT
    • ThomasLT Studio
The GB is live right now!!! Come have a look.
Offline ThomasLT
    • ThomasLT Studio
Sound test on YouTube now, don’t forget to check it out!
Offline SirKeebsalittle
Re: [GB] Rich75 - A 75% tri-mode with monitor keyboard | GB is live right now
« Reply #5 on: Mon, 09 September 2024, 10:11:58 »
Hi! Since the GB ended about a month ago - is there an update on manufacturing/progress here? Thanks!
Offline SadEgg
« Reply #6 on: Sun, 29 September 2024, 22:53:23 »
I second this, haven't heard anything back since the groupbuy ended, no response from emails either. This is my first mechanical keyboard so I'm not sure whether to be concerned or not?
Offline Webkozo
« Reply #7 on: Mon, 30 September 2024, 10:55:10 »
For what it's worth, they've posted about the GB recently on their Discord. Should check there.
Offline SadEgg
« Reply #8 on: Mon, 30 September 2024, 18:44:56 »
Ahh super helpful, thank you. That does seem to be where all the updates are. A bit embarrassing on my part now!
Offline nessMINI
« Reply #9 on: Fri, 11 October 2024, 17:48:18 »
I'm confused to why this keyboard even needs to exist.
Offline SwitchKeys
    • SwitchKeys
« Reply #10 on: Tue, 29 October 2024, 20:13:28 »
FYI OP hasn't been active on here since August.
