Author Topic: Re: [IC] MW Asuka -GB live!  (Read 17383 times)
Offline MILKYWAY KEYS
  • PBT keycap manufacturer
    • MilkywayKeys
« on: Fri, 05 July 2024, 00:24:57 »
MW Asuka
IC
BASE+NOV
Translucent Alpha
Norde Kit
Num Kit
40S Kit
Space Kit
Renders
USB cable
Vendors
GB Dates
July 21-August 21, 2024
Contact
Instagram: @milkywaykeys
Discord Server: Milkyway Keys
[/quote]
« Last Edit: Wed, 23 October 2024, 21:09:25 by MILKYWAY KEYS »
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #1 on: Fri, 05 July 2024, 00:27:15 »
revised
« Last Edit: Fri, 05 July 2024, 00:31:43 by MILKYWAY KEYS »
Offline keepoto
  • HHKB top for TKL pls
Re: [IC] MW Asuka
« Reply #2 on: Fri, 05 July 2024, 03:30:28 »
Offline xLeHoy
  • weeb board enjoyer
Re: [IC] MW Asuka
« Reply #3 on: Fri, 05 July 2024, 04:25:48 »
The colors sadly represent her plugsuit and EVA more than Asuka herself so not really a fan of this.
Still GLWIC
Offline keepoto
Re: [IC] MW Asuka
« Reply #4 on: Fri, 05 July 2024, 05:48:33 »
Still GLWIC
wdym, Asuka is her plugsuit you false believer
Offline keepoto
Re: [IC] MW Asuka
« Reply #5 on: Fri, 05 July 2024, 05:49:13 »
also can we get a non-translucent enter in base? or did i miss that
Offline yo1000
Re: [IC] MW Asuka
« Reply #6 on: Fri, 05 July 2024, 07:28:14 »
I'm on board I'll take every kit guaranteed, I'm a shill for this set. I am interested !
Offline cthalupa
Re: [IC] MW Asuka
« Reply #7 on: Fri, 05 July 2024, 13:41:54 »
Still GLWIC
Pretty common for weeb sets to focus on colors from iconic clothing for the character, and I might even argue that it's kind of the norm. But for Asuka in specific, even the high end official collab merch like the Fender custom shop telecaster or the recent Asus gear will actually be Eva-02 or plugsuit colored. The Tele was specifically Asuka branded as well.
I don't mind the colors but the novelties aren't super interesting to me. Overwhelming majority are effectively just text novs and I don't find them particularly interesting. There's also just errors that have been pointed out multiple times on the MW Evangelion sets that aren't fixed. e.g. 'evabacing' - the kanji is '暴走' which means acting recklessly or rampaging, or, in computer science, runaway process. It's pronounced  ぼうそう/bousou. Is it supposed to be 'evacuating'? But that still wouldn't make sense for those kanji - when it's translated as runaway, it doesn't mean 'running away/fleeing', it means 'out of control.' But in general it feels like the novelties are largely just some kanji and text thrown down onto a keycap. Which, if you're just going to shameless copy the IP, why not copy some of the amazing iconography from the series? It fits a bit with the design of the computer interfaces and how they would frequently have big kanji words flashing over the rest of the screen, but that's basically the entire identity of the set, novelty wise. If this is an Asuka set, where are the A-10 clips? Where is the Lance? If you're going the Rebuild route, where is the eyepatch?
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #8 on: Fri, 05 July 2024, 19:34:10 »
Thanks for the advice, I'll take it into consideration
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #9 on: Fri, 05 July 2024, 19:35:31 »
Thanks for the like and support! ;D
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #10 on: Fri, 05 July 2024, 19:39:55 »
Still GLWIC
Receive your suggestions, we will seriously consider and modify the
« Last Edit: Fri, 05 July 2024, 20:35:10 by MILKYWAY KEYS »
Offline aicyborg
Re: [IC] MW Asuka
« Reply #11 on: Fri, 05 July 2024, 22:04:20 »
Your base kit currently has the UK specific keys ~# and @" in base as well as in the Norde kit. They can be omitted from the base kit if they're in the Norde kit.
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #12 on: Sat, 06 July 2024, 03:13:56 »
Thanks for the heads up.
Offline dvorcol
  • Discord: dvorcol_5071
Re: [IC] MW Asuka
« Reply #13 on: Sat, 06 July 2024, 14:05:52 »
All the pictures all say R2. Where can we see what the first round was like?
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #14 on: Sun, 07 July 2024, 04:45:58 »
https://www.zfrontier.com/app/flow/2vm6m6NzWxgB
Here's a link to the R1, which was only available in the China region at the time
Offline SolidBrain
Re: [IC] MW Asuka
« Reply #15 on: Mon, 08 July 2024, 23:58:04 »
7 days till gb start, will vendor details be updated? GLWIC!
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #16 on: Thu, 11 July 2024, 03:42:23 »
We're choosing vendors.
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #17 on: Fri, 12 July 2024, 02:02:31 »
Still GLWIC
To correct the translation errors of "暴走" and "兽化" in NOV
Offline cthalupa
Re: [IC] MW Asuka
« Reply #18 on: Fri, 12 July 2024, 02:56:15 »
Awesome!
I'm in for base kit/alphas/numpad/spacebars then.
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #19 on: Mon, 15 July 2024, 04:58:09 »
Awesome!
Thank you for your support. ;)
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #20 on: Tue, 16 July 2024, 20:55:51 »
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #21 on: Thu, 18 July 2024, 04:49:32 »
vendors update
« Last Edit: Wed, 24 July 2024, 02:12:43 by MILKYWAY KEYS »
    • MilkywayKeys
« Reply #22 on: Wed, 24 July 2024, 02:09:49 »
vendor update
« Last Edit: Wed, 24 July 2024, 02:12:03 by MILKYWAY KEYS »
    • MilkywayKeys
Re: [IC] MW Asuka
« Reply #23 on: Wed, 24 July 2024, 02:10:42 »
USB cable update
Offline Hache-eLle
« Reply #24 on: Fri, 02 August 2024, 18:35:48 »
How come no spacebars with the Translucent ABS coating in red & orange to match the ascents and "Alpha" kit?
    • MilkywayKeys
« Reply #25 on: Fri, 02 August 2024, 21:10:43 »
I'm sorry. It was a lapse in judgment.
    • MilkywayKeys
« Reply #26 on: Sat, 03 August 2024, 04:01:06 »
If the MOQ is met, customers purchasing alpha will receive 6.25 and 7Uspace for free! :D
Offline Hache-eLle
« Reply #27 on: Thu, 08 August 2024, 06:33:20 »
How far off are you from the MOQ?
    • MilkywayKeys
« Reply #28 on: Fri, 09 August 2024, 02:24:54 »
Currently almost reached MOQ :cool:
