Author Topic: Razer Analog V2  (Read 4141 times)
Offline Atlasblissed
Razer Analog V2
« on: Sat, 06 July 2024, 04:14:06 »
Does anyone know if the Razer Analog V2 switches can be lubed without affecting the keyboard's functionality?
I have already lubed the stabilizers and switch stabilizers, but the sound produced is still bad.
Online Rhienfo
  • GOTHETIGES
Re: Razer Analog V2
« Reply #1 on: Fri, 12 July 2024, 02:12:50 »
Generally would recommend against lubing those styles of optical switches. It might be fine but if lube starts to move around it could interfere with the acuation of the switch. I don't think lubing the switches would give any benefit to the sound anyway as well.
