Author Topic: [IC] Hiexa G Series-G60 New Mounting, One Button Quick Disassembly Keyboard  (Read 10710 times)
Offline Hiexakey
    • Hiexakey Official Website
Hi Everyone,
This is HiexaKey again. We have previously introduced our Hiexa V series to the community.
Today, we will introduce the first product of the brand new G series: Hiexa G60.
I am sure everyone has childhood memories, some of which you still feel nostalgic for until today.
One of the essential parts of mine is my passion and love for video games, especially handheld console games.
However, for some reason, I've never been able to have a handheld game console of my own when I was a child.
Now, I can combine it with the keyboard, which is also a way to make up for the regret of my childhood!
Pink prototype
Black prototype
Tiffany prototype
Render Gallery
Black-colorful-HHKB        Sand-blue-HHKB
Tiffany-pink-HHKB        Pink-white-HHKB
Orange-black-WK        Red-blue-WK
Wine Red+milky-WK        Silver-WK
White-dark purple+milky-WKL        White-turquoise+milky-WKL
Purple-white-WKL
Design
Front design
Combining the classic elements and the double L-shaped bars is a decoration and part of the structure, practical as well as elegant and aesthetic.
There are WK, WKL, and HHKB layout options.
Side design
It adopts an upper, middle, and lower splicing method and combines it with geometric protrusions for visual features.
The RGB strips are embellishments, and you can adjust the colors and brightness of RGB lighting for different atmospheres.
The side of the bottom case shell utilizes cutting techniques to create a three-dimensional visual effect!
Back design
It combines game and handheld game console styles, with multiple CNC parts matching each other to make the overall style more complete!
Structure
Ball Catch Structure
We have adopted a suitable ball catch for the keyboard case, which can be symmetrically distributed on the shell.
Quick-release Button
We have added a convenient quick-release button to the bottom case.
By pressing it, you can now quickly and easily release the ball catch system with one hand.
Limit Stopper
It prevents scratches caused by the case's disassembly and assembly and serves as a limit for the keyboard inner.
Magnetic Connector
It is the same as the Hiexa V series, which can simplify the assembly process.
Brass Internal Weight
It integrates two batteries(Tri-mode) inside to make the interior flat for a better typing sound.
Although the internal cannot be seen after assembly, we still designed patterns to make the overall design more perfect!
New Mounting
The G60 adopts the new spring buffer structure. Through continuous testing, we finally found the appropriate spring data.
With the support of a spring, the buffer of FR4, and the silicone socks, we have obtained the spring structure we need.
Typing Sound
■ Wired HS PCB
■ Tri-mode HS PCB----wired, Bluetooth 5.0, and 2.4G mode.
Support QMK/VIA
Support multiple layout
Include 4400MHA capacity battery (Tri-mode only)
■ Plate----POM, FR4, ALU
■ Foam----PORON plate foam + IXPE foam + EPDM case foam and PET insulating foam.
Color Option and Finish
Glitter Spray-coated Case:
Sand-blue, Black-colorful, White-turquoise, White-dark purple, Red-blue
Wine Red+milky, Orange-black, Purple-white, Pink-white
Anodized Case:  Silver
Note: The Weight of silver is make by alu not brass,due to need to keep the color same as the case.
Specification
■ Typing angle: 7°
■ Front height: 19.2mm
■ Front length and width: 298.6*116.5mm
■ Support PCB stabilizers
Content List
CNC Case x 1
L-shaped bars x 2
Brass Weight x 1
Brass Internal Weight x 1
Plate x 1
HS PCB x 1
IXPE Foam x 1
3.5mm Poron Foam x 1
EPDM Foam x 1
PET Insulation Sheet x 1
Footpads x 1
2200mAh Battery x 2 ( Only for the tri-mode)
2.4GHz Receiver x 1
Silicone pack x 1
Extra Screws pack x 1
Carry case x 1
Price
Around USD219
Sale Method
Limited in stock and Group Buy
IC Form
Please fill out the IC form to share your thoughts with us. It means a lot to us.  Thanks.
Discord
We welcome you to join our server for faster updates and discussion.
Thank you so much for your time.
Best Regards
HiexaKey
« Last Edit: Thu, 19 September 2024, 05:15:46 by Hiexakey »
Offline hzh0525
Gameboy wins!
Looks Nice
GLWIC
Sent from my Pixel 7 Pro using Tapatalk
Offline Hiexakey
Offline Hiexakey
Looks Nice
GLWIC
Thank you :cool:
Offline Hiexakey
Pink prototype update
Offline Mykeeb
The design is so cool :thumb: When it will be GB?
Offline Hiexakey
Thanks :) We are preparing the prototypes. The GB will launch in late September or early October.
Offline Keebzncables
Can't wait for this one.
Offline Hiexakey
You can follow us or join our discord so you won't miss any updates.
Offline Hiexakey
Re: [IC] Hiexa G Series-G60 New Mounting, One Button Quick Disassembly Keyboard
« Reply #10 on: Thu, 19 September 2024, 05:09:37 »
Hi everyone, we have added a new color, Tiffany, and updated the prototypes for both Black and Tiffany. :)
Offline vhaarr
« Reply #11 on: Thu, 19 September 2024, 06:38:25 »
Does the plate+pcb support 1.75u+1u split right shift?
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline Hiexakey
« Reply #12 on: Thu, 19 September 2024, 21:51:29 »
Yes, it supports 1.75u + 1u split right shift.
Offline CaptainSterling
« Reply #13 on: Fri, 20 September 2024, 15:57:30 »
Really vibing with this one. The nostalgia is STRONG. Would love to check it out if you're looking for content creators!
Offline Hiexakey
« Reply #14 on: Sun, 22 September 2024, 21:21:19 »
Thank you! We’ll definitely consider it!
