Author Topic: 【IC】Chosfox X JWK Adaptive Elastic Structure Stabilizer Set  (Read 6491 times)
Offline chosfox
Hello everyone, This is Chosfox.
This time it brings a new stabilizer in collaboration with JWK
Stabilizers are designed to help the large keys to keep balance on mechanical keyboards.
The PCB stabilizer is screwed onto the PCB plate (to stabilize the keys), and the steel plate satellite shafts are snapped onto the positioning board (simple and easy to use), while the 7U/6.25U represents the space length of the keyboard
With two types of gasket
Steel plate mount stabilizer repair pad (Teflon)——Affixed to the PCB board at the bottom of the satellite shaft
steel wire gasket —Placed on the PCB at the corresponding position of the steel wire
Offline mmayhem17
    • Steam profile
Re: 【IC】Chosfox X JWK Adaptive Elastic Structure Stabilizer Set
« Reply #1 on: Wed, 17 July 2024, 06:00:02 »
what exactly is new in this one? looks just like jwk v2s, but a few marketing words in it...
Offline Surefoot
« Reply #2 on: Wed, 17 July 2024, 13:48:17 »
Have you looked at the first post, and read it ?
@Chosfox: when, and where ? Will they be available through Keygem ? Or at least KBDFans or KPRepublic ?
Offline chosfox
« Reply #3 on: Thu, 18 July 2024, 02:16:49 »
It's a new co-branded stabilizer collaboration between Chosfox and JWK, and it's only available at Chosfox.com at the moment!
Learn more:https://chosfox.com/products/jwk-x-chosfox-elastic-structure-stabilizer-set
Offline chosfox
« Reply #4 on: Thu, 18 July 2024, 02:18:25 »
This is a new co-branded stabilizer from Chosfox and JWK, find out more about it:https://chosfox.com/products/jwk-x-chosfox-elastic-structure-stabilizer-set
Offline VXQN
« Reply #5 on: Thu, 18 July 2024, 03:01:43 »
So this is an interest check, for a product that's already available. Okay. I have to say this whole thread is pretty uninformative:
As someone unfamiliar with JWK stabilizers, I also wonder what's the difference between this collaboration and regular ones?
Both here and on the product page there is no explanation about what the "self-adjusting elastic structure" actually is. Can you go into further detail?
There's also no explanation about what the various gaskets are for. I can tell that some go on the PCB, underneath the main housing, but I have no idea about the others. If they're for "holee" modding or similar, then surely that indicates that this "elastic" structure is insufficient to remove noise?
Offline chosfox
« Reply #6 on: Thu, 18 July 2024, 05:07:27 »
The plastic bottom can reduce the space for the steel wire to move, which can greatly avoid the influence of the steel wire on the overall quality, and can reduce the noise.
Offline chosfox
« Reply #7 on: Thu, 18 July 2024, 05:08:21 »
Offline PlasticSporkz
« Reply #8 on: Sun, 28 July 2024, 01:56:59 »
Are these the same as the Designer Studios adaptive stabs being sold at Clickclack? https://clickclack.io/collections/in-stock-accessories/products/in-stock-designerstudio-adaptive-pcb-mount-stabilizer
Ducky Shine 2, Poker II, Leopold FC980M x2. Cherry Blues
