Author Topic: Replace caps on Cherry G80  (Read 4390 times)
Offline BeerSerc
« on: Mon, 25 October 2010, 09:50:51 »
Hi,
I am a long time passive user of geekhack, but as I finally bought a G80 3000 some 5 months ago, I thought it's time to register.
I am very happy with the blue Cherry switches in the G80, but these keys with the logo of some strange operating system are annoying.
I searched around for replacement caps for those 2 keys, but I only found strange companies selling custom caps, mostly with a lot of 404 errors on their pages.
Isn't there a shop out there, optimally somewhere in Europe, which sells replacement keycaps for Cherry Keyboards?
cu
BeerSerc
Offline Moogle Stiltzkin
« Reply #1 on: Mon, 25 October 2010, 11:39:59 »
Hm all i know is that
1. the spacing between keys on cherry keyboard may be slightly different (someone plz confirm this)
2. the spacebar for cherry keyboard is different underneath as the switch is more to the right rather than dead center of the spacebar. So if you do try to find a replacement spacebar, check underneath whether it is cherry keyboard compatible
3. cherry keyboards use their own stabilizers made of rubber. This is perfectly fine and convenient since removing/installing keys with stabilizers for the cherry keyboard is much simpler/easier.
4. i don't think cherry sells their keycaps separately. The best i've seen are keycaps canabalized off other Cherry keyboards.
Anyway hope that helped. Maybe someone else who knows more can help.
Royal Kludge discount code:
Lowyat15
15 USD discount.
Offline 7bit
  • MX1A-G1DW
« Reply #2 on: Mon, 25 October 2010, 11:52:10 »
Quote from: BeerSerc;238401
Hi,
cu
BeerSerc
You obviously missed the double-shot key cap order thread:
http://geekhack.org/showthread.php?t=11998
Signature Plastic makes them for us. You should ask WhiteRice if he still has a contingent available.
These keys will fit your Cherry board.
Welcome to geekhack!
Buy key caps here: Round 5
Buy switches here: CherryMX
« Reply #3 on: Mon, 25 October 2010, 11:55:53 »
@7bit
But the spacebar probably won't.
Lowyat15
15 USD discount.
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #4 on: Mon, 25 October 2010, 13:09:33 »
If that's the only problem - well, on a current-production sample with lasered keys you should be able to attack the labeling with sandpaper, or sandblast it Ripster-style.
Offline keyboardlover
« Reply #5 on: Mon, 25 October 2010, 13:16:22 »
Does anyone know what rollover the G80 3000 has? I didn't see it listed in the wiki. Would be great if maybe BeerSec could do a test for us :D
Offline sixty
    • http://deskthority.net
« Reply #6 on: Mon, 25 October 2010, 13:23:10 »
Quote from: keyboardlover;238491
2 keys.
Offline Senor_Cartmenez
« Reply #7 on: Tue, 26 October 2010, 08:10:03 »
I asked those cherry fools and their local distributors in Germany for custom/seperate keysets.
" We are sorry but blablablablabla"
Lazy bastards
Offline BeerSerc
« Reply #8 on: Mon, 01 November 2010, 15:21:40 »
Yes, I can confirm 2 key rollover.
Thanks for the infos, I'll check the other thread.
cu
BeerSerc
