Author Topic: Dyeing PBT caps with laser etched labels?  (Read 11316 times)
Offline jfloren
« on: Wed, 31 July 2024, 12:07:06 »
I've used the FK custom designer to lay out something I'm pretty pleased with in XDA PBT caps, but of course they only come in white. I'd like to get a bit more color on, so I'm looking at dyeing.
I've found good guides on how to do it, but I haven't been able to verify if the legends will hold up. Apparently they're laser etched, but I assume some sort of color is then applied? Will that hold up to the dye?
Edit: thought they were dye sublimation, looked closer and it turns out it's a laser etching
« Last Edit: Wed, 31 July 2024, 15:07:55 by jfloren »
